I just picked up two 2 GB sets of xms2-8500 dominator, and neither one of them will work in my system (see sig). I tried just installing them in place of my ballistix, with no changes to the bios settings, because I figured they'd boot right up and then I could adjust the speed and timings in the bios. That was a no go, the system wouldn't even post. So, I reinstalled my ballistix, got into the bios and loaded the default settings (except changing the volts to 2.1 per the memory specs), reinstalled the corsair, and same thing, no post. So then I repeated the previous procedure again, except this time I manually set the memory timings and speed to 1066. This let me get all the way to the vista loading screen, before I got a BSOD.
Is there some magic trick to getting these things to work that I don't know about? Some issue with this mobo/ram combo I don't know about? It would be some seriously bad luck if I got two DOA sets, but that's all I can figure.
