Lone_Bullet.be
- Jul 26, 2005
Hi there,
I have a MSI P6NGM with tha nforce 630i + geforce 7100 onboard.
When I try and use the DVI - > HDMI ( DVI onboard - HDMI on the monitor ) cable my screen seems to have an offset to the highleft and the resolution seems bigger.
The 'rest' of the screen is collored black. Yes, i've tried the ' auto ' button on my monitor
Now, i'm forced to use analog on my LG L245 PW wich gives me a quite blurry ( hurting my eyes, otherwise i wouldn't complain ) screen. the analog connection has no problems with an offset nor has any other problems.
I'm not sure if it is the monitor or the IGP as I has the monitor on DVI -> HDMI on a GF8800GTS 320 without any problems. I tried other cables without any better result.
My previous IGP motherboard ( Abit F-I90HD with ATI R X600 IGP ) did not have any problems either.
I'm using the newest nforce drivers ( has the gpudrivers in it ) and i am running at native res
( 1920 * 1200 )
I also have the newest BIOS and have it set to IGP mode, the monitor is also set at ' PC mode '.
Can anyone help me?
Thank you kindly.
( 1920 * 1200 )
Can anyone help me?
Thank you kindly.
