Just got a Dell Dimension 8400 yesterday. Went to partition the 80G drive for my needs and used fdisk to delete partitions. I popped in my XP recovery disk and it started to load some files then got to a point where it prompts 3 options. Install XP, Repair XP, and some other option. I select to install XP and says that no hard disk can be found. I copied the SATA/RAID drivers onto a floppy from the Resource CD and copied them by pressing F6 and I still get the same result. Any ideas?
I called tech support and they are sending me a new HD with XP installed on it but I still would like to get this resolved for future reference.
