Problem installing Graphic card drivers for GTX 660 on windows 7
Discussion in 'Operating Systems' started by davidcarey, Dec 30, 2017.
  1. davidcarey
    davidcarey n00b
    31
    Dec 17, 2017
    I am having some difficulty installing the GTX660 drivers on windows 7 , Is this a Nvidia or Windows issue ? "Nvidia installer failed" . Insanely long download time as well ( tried to download an earlier one )
  2. DrLobotomy
    DrLobotomy [H]ardness Supreme
    6,426
    May 19, 2016
    Where did you download them from? Or are you trying to use the built in updater in the NVidia control panel?
  3. davidcarey
    davidcarey n00b
    31
    Dec 17, 2017
    Downloaded from Nvidia , Version 388.71 which is the latest . Going to try and uninstall the current driver later and see if that helps . Why are these drivers so difficult ? I updated my BIOS with one click !
  4. B00nie
    B00nie [H]ardness Supreme
    7,995
    Nov 1, 2012
    I just installed a GTX660 to my uncle (although Windows 8.1) without any problems. I used DDU (display driver uninstaller) prior to the install.
  5. davidcarey
    davidcarey n00b
    31
    Dec 17, 2017
    B00nie DDU needs .NET framework ,which I cannot get installed ( along with SP1 and visual C++ ! ) . Need those programs to get other programs to work , which is kind of ridiculous !
    NOTE . I just ran a scan on the downloaded DDU file from Guru3d , and hbpix automatically downloaded !!
  6. AltTabbins
    AltTabbins [H]ard as it Gets
    19,258
    Jul 29, 2005
    Wait. Why can’t you get sp1 installed?
  7. grasshoppa
    grasshoppa 2[H]4U
    2,377
    Jun 18, 2017
    Sounds like the windows install is fubar'd. I'd start by doing a wipe and reload.
    I'd also test the HDD while I'm at it.
  8. BulletDust
    BulletDust [H]ardness Supreme
    6,057
    Feb 17, 2016
    DDU's saved my ass a couple of times, sadly it's ability to completely block Windows 10 graphics driver updates is all but dead though....
    Still a great option for completely wiping drivers and starting again though. You're installing with Admin privileges aren't you?
  9. davidcarey
    davidcarey n00b
    31
    Dec 17, 2017
    Just did a clean Win 7 pro 64 install on a separate hard disc from CD ( something went pear shaped with the OS ) , all updates inc SP1 went well and listed as "windows up to date" But , SP1 is listed in update history as successful , but not listed in installed updates and still not . I installed ( so I thought ) SP1 first . Can anyone please explain why this is still not getting installed ?
  10. grasshoppa
    grasshoppa 2[H]4U
    2,377
    Jun 18, 2017
    Any time I start getting this kind of weird ass behavior, I start suspecting the powersupply or motherboard.
    But let's run this down logically. You a) installed OS on clean drive ( same computer ) b) put it on network ( did you have to install any network drivers? ) c) immediately went to windows update and patched it up.
    Is that about right?
  11. davidcarey
    davidcarey n00b
    31
    Dec 17, 2017
    OK , so windows update informed me of a load of additional updates ( Less than a day after "up to date" ) including SP1 ( again ) , so I let it do its thing ( again ) and bingo it is now listed as win 7 pro service pack 1 (Build 7601 ) , and I have two listings in Update history . Now all I have to do is find the product ID in the original hard drive !
    Windows completely baffles me ! Now I have the third bunch of updates ( after 2 days and twice being informed that the system is up to date ) , this time for 200 new updates !
  12. greyeyezz61
    greyeyezz61 n00b
    7
    Sep 3, 2016
    Are those newer drivers compatible with that old card?
  13. davidcarey
    davidcarey n00b
    31
    Dec 17, 2017
    Yes the driver pack from Nvidia , 388.71 and Every thing else is working well ( touch wood ) new windows 7 pro installation , upgraded to SP1 , .Net and visual C++ . Card is working well , tested it on Assassins creed Black flag , and apart from a little stutter ( and Many other , far more powerful , cards have the exact same problem ) works flawlessly . My expectations have been exceeded .
  14. greyeyezz61
    greyeyezz61 n00b
    7
    Sep 3, 2016
    I have a GTX660 SO and every time I updated the drivers it introduced another problem or issue. I found a stable version and haven't updated since nor am I. 347.88
