It's always really bothered me that computers, cases, and airflow typically don't work well together, there's a lot of 90 degree angles, perpendicular cooling, and working against hot air rising.
I had the idea to use PCI-Express extenders with graphics cards that have vertically aligned coolers (Gigabtye Windforce) remove the fans and to try to cool the whole system with only 2 fans and work with airflow and hot air rising. Here's my initial mock up, you could fit 4 3.5in drives on the opposite side of the motherboard, there's plenty of space back there because of the SFX PSU. If I was actually constructing the case, I would remove the shroud and fan from the PSU, It'll probably be nesicary to construct plastic air ducts to guide as much air as possible through the heat sinks. I'm still looking for the ideal CPU cooler to use for concepting. I'd like to keep it as quiet as possible, the top would have sound damping material that breathes to let the air out while minimizing noise and not holding heat next to your components.
Currently cable management and wiring hasn't be given too much though besides leave some space for it. The SFX PSU as a lot of room to be re-positioned.
Please tell me if this idea is stupid and why. Silent, powerful, and small PCs have always interested me.
Please imagine vertically aligned heatsink without fans on the GPUs and CPU. I'm planning on doing some photo-realistic renders once everything is planned and modeled.
