| | | | | | Elapsed | CPU Time | | Average | | | | | |
Computer | Clock | Cores | Clock*Cores | Mem Chan | Threads/Core | MT Threads | Avg | Avg | # Running | hr/WU | WU/day | PPD | Utilization | % |
2P E5-2695V3 (L) | 2.7 | 28 | 75.6 | 8 | 1 | 14 | 9084 | 108330 | 2 | 2.52 | 19.02 | 114135 | 11.93 | 85% |
2P E5-2695V3 (L)** | 2.7 | 28 | 75.6 | 8 | 1 | 7 | 15894 | 105887 | 4 | 4.42 | 21.74 | 130464 | 6.66 | 95% |
2P Epyc 7601 (L) | 2.7 | 64 | 172.8 | 16 | 1 | 16 | 16960 | 234382 | 4 | 4.71 | 20.38 | 122264 | 13.82 | 86% |
2P Epyc 7601 (L)** | 2.7 | 64 | 172.8 | 16 | 1 | 8 | 25659 | 194229 | 8 | 7.13 | 26.94 | 161627 | 7.57 | 95% |
2P Epyc 7601 (L) | 2.7 | 64 | 172.8 | 16 | 1 | 4 | 46840 | 183854 | 16 | 13.01 | 29.51 | 177079 | 3.93 | 98% |
Ryzen 5900X (L)** | 4.1 | 12 | 49.2 | 2 | 1 | 6 | 12225 | 70810 | 2 | 3.40 | 14.13 | 84810 | 5.79 | 97% |
Ryzen 5900X (L) | 4.1 | 12 | 49.2 | 2 | 1 | 3 | 24555 | 72849 | 4 | 6.82 | 14.07 | 84447 | 2.97 | 99% |
Ryzen 5900X (L) | 4.1 | 12 | 49.2 | 2 | 1 | 1 | 101588 | 101513 | 12 | 28.22 | 10.21 | 61236 | 1.00 | 100% |
E5-2683V4 (L) | 2 | 16 | 32 | 4 | 1 | 16 | 12248 | 168199 | 1 | 3.40 | 7.05 | 42325 | 13.73 | 86% |
E5-2683V4 (L) | 2 | 16 | 32 | 4 | 1 | 8 | 21308 | 161094 | 2 | 5.92 | 8.11 | 48658 | 7.56 | 95% |
E5-2683V4 (L)** | 2 | 16 | 32 | 4 | 1 | 4 | 37336 | 146775 | 4 | 10.37 | 9.26 | 55539 | 3.93 | 98% |
Xeon Phi 7250 (L) | 1.3 | 68 | 88.4 | 8 (MCD) | 1 | 17 | 26577 | 259245 | 4 | 7.38 | 13.00 | 78022 | 9.75 | 57% |
Xeon Phi 7250 (L)** | 1.3 | 68 | 88.4 | 8 (MCD) | 1 | 4 | 58450 | 223799 | 17 | 16.24 | 25.13 | 150775 | 3.83 | 96% |
i9 10980XE (W) | 2.8 | 18 | 50.4 | 4 | 1 | 9 | 7755 | 62610 | 2 | 2.15 | 22.28 | 133694 | 8.07 | 90% |
i9 10980XE (W)** | 2.8 | 18 | 50.4 | 4 | 1 | 6 | 11175 | 63078 | 3 | 3.10 | 23.19 | 139168 | 5.64 | 94% |
i9 10980XE (W) | 2.8 | 18 | 50.4 | 4 | 1 | 4 | 15782 | 61342 | 4 | 4.38 | 21.90 | 131390 | 3.89 | 97% |
i9 10980XE (W) | 2.8 | 18 | 50.4 | 4 | 1 | 3 | 33806 | 99490 | 6 | 9.39 | 15.33 | 92007 | 2.94 | 98% |
i9 10980XE (W) | 2.8 | 18 | 50.4 | 4 | 1 | 1 | 150337 | 150093 | 18 | 41.76 | 10.34 | 62069 | 1.00 | 100% |
2P E5-2698V4 (L) | 1.9 | 40 | 76 | 8 | 1 | 20 | 11734 | 180791 | 2 | 3.26 | 14.73 | 88359 | 15.41 | 77% |
2P E5-2698V4 (L) | 1.9 | 40 | 76 | 8 | 1 | 10 | 17383 | 159685 | 4 | 4.83 | 19.88 | 119289 | 9.19 | 92% |
2P E5-2698V4 (L)** | 1.9 | 40 | 76 | 8 | 1 | 5 | 31472 | 153034 | 8 | 8.74 | 21.96 | 131774 | 4.86 | 97% |
Ryzen 3950x (L) | 3.7 | 16 | 59.2 | 2 | 1 | 16 | 9151 | 132073 | 1 | 2.54 | 9.44 | 56650 | 14.43 | 90% |
Ryzen 3950x (L)** | 3.7 | 16 | 59.2 | 2 | 1 | 8 | 15680 | 120292 | 2 | 4.36 | 11.02 | 66122 | 7.67 | 96% |
Ryzen 3950x (L) | 3.7 | 16 | 59.2 | 2 | 1 | 4 | 33018 | 129713 | 4 | 9.17 | 10.47 | 62802 | 3.93 | 98% |
Ryzen 3700X (W)** | 3.5 | 8 | 28 | 2 | 1 | 8 | 9404 | 10919 | 1 | 2.61 | 9.19 | 55125 | 1.16 | 15% |
Ryzen 3700X (W) | 3.5 | 8 | 28 | 2 | 1 | 4 | 18995 | 18849 | 2 | 5.28 | 9.10 | 54583 | 0.99 | 25% |
Ryzen 5800X3D (W)** | 4.3 | 8 | 34.4 | 2 | 1 | 8 | 8093 | 13545 | 1 | 2.25 | 10.68 | 64055 | 1.67 | 21% |
Ryzen 5800X3D (W) | 4.3 | 8 | 34.4 | 2 | 1 | 4 | 15779 | 17457 | 2 | 4.38 | 10.95 | 65708 | 1.11 | 28% |
Ryzen 5800X3D (W) | 4.3 | 8 | 34.4 | 2 | 1 | 1 | 62124 | 55987 | 8 | 17.26 | 11.13 | 66757 | 0.90 | 90% |
If you have 7950x, it will run much faster, at least according to this post in TAAT forum. 11 hrs for 5950x versus 7 hrs for 7950x. My guess is that it could be due to AVX-512 and larger L3 cache memory. I believe the ETA run time is based on 8 cores per task.I was able to run two tasks just to see if one project was faster than the other. The results were extremely close and the difference is probably FAH in the background using a virtual thread or me browsing the internet.
CPU: AMD 5900X (6 threads/task)
Cullen -
Run Time: 42,291
CPU Time: 245,282
Credit: 29,125
Points Per Second Run Time: 0.689 p/s or 59,529 ppd
Woodall -
Run Time: 39,346
CPU Time: 228,072
Credit: 27,198
Points Per Second Run Time: 0.691 p/s or 59,702 ppd
2P E5-2695V3 (L)** | 2.7 | 28 | 75.6 | 8 | 1 | 14 | 25491 | 326641 | 2 | 7.08 | 6.78 | 184724 |
2P E5-2695V3 (L) | 2.7 | 28 | 75.6 | 8 | 1 | 7 | 50935 | 345415 | 4 | 14.15 | 6.79 | 184894 |
2P Epyc 7601 (L) | 2.7 | 64 | 172.8 | 16 | 1 | 16 | | | 4 | 0.00 | #DIV/0! | #DIV/0! |
2P Epyc 7601 (L)** | 2.7 | 64 | 172.8 | 16 | 1 | 8 | 74116 | 572537 | 8 | 20.59 | 9.33 | 254131 |
Ryzen 5900X (L)** | 4.1 | 12 | 49.2 | 2 | 1 | 12 | 21044 | 239982 | 1 | 5.85 | 4.11 | 111880 |
Ryzen 5900X (L) | 4.1 | 12 | 49.2 | 2 | 1 | 6 | 43506 | 256232 | 2 | 12.09 | 3.97 | 108233 |
E5-2683V4 (L) | 2 | 16 | 32 | 4 | 1 | 16 | | | 1 | 0.00 | #DIV/0! | #DIV/0! |
E5-2683V4 (L)** | 2 | 16 | 32 | 4 | 1 | 8 | 60743 | 468757 | 2 | 16.87 | 2.84 | 77520 |
Xeon Phi 7250 (L) | 1.3 | 68 | 88.4 | 8 (MCD) | 1 | 17 | | | 4 | 0.00 | #DIV/0! | #DIV/0! |
Xeon Phi 7250 (L)** | 1.3 | 68 | 88.4 | 8 (MCD) | 1 | 8 | 104245 | 747953 | 8 | 28.96 | 6.63 | 180682 |
i9 10980XE (W)** | 2.8 | 18 | 50.4 | 4 | 1 | 9 | 26102 | 213811 | 2 | 7.25 | 6.62 | 180400 |
i9 10980XE (W) | 2.8 | 18 | 50.4 | 4 | 1 | 6 | 52093 | 297442 | 3 | 14.47 | 4.98 | 135588 |
2P E5-2698V4 (L) | 1.9 | 40 | 76 | 8 | 1 | 20 | 28800 | 494923 | 2 | 8.00 | 6.00 | 163500 |
2P E5-2698V4 (L)** | 1.9 | 40 | 76 | 8 | 1 | 10 | 50004 | 475368 | 4 | 13.89 | 6.91 | 188337 |
Ryzen 3950x (L)** | 3.7 | 16 | 59.2 | 2 | 1 | 16 | 26925 | 407896 | 1 | 7.48 | 3.21 | 87443 |
Ryzen 3950x (L) | 3.7 | 16 | 59.2 | 2 | 1 | 8 | 52042 | 405342 | 2 | 14.46 | 3.32 | 90481 |
Ryzen 3700X (W)** | 3.5 | 8 | 28 | 2 | 1 | 8 | 31009 | 19192 | 1 | 8.61 | 2.79 | 75926 |
Ryzen 3800X (W)** | 4.4 | 8 | 35.2 | 2 | 1 | 8 | 28124 | 219650 | 1 | 7.81 | 3.07 | 83715 |
Ryzen 5800X3D (W)** | 4.3 | 8 | 34.4 | 2 | 1 | 8 | 22558 | 24977 | 1 | 6.27 | 3.83 | 104371 |
Computer | Clock | Cores | Clock*Cores | Mem Chan | Threads/Core | MT Threads | Avg | Avg | # Running | hr/WU | WU/day | PPD | |
2P E5-2695V3 (L)** | 2.7 | 28 | 75.6 | 8 | 1 | 14 | 27368 | 350324 | 2 | 7.60 | 6.31 | 184367 | |
2P E5-2695V3 (L) | 2.7 | 28 | 75.6 | 8 | 1 | 7 | 57461 | 391490 | 4 | 15.96 | 6.01 | 175624 | |
2P Epyc 7601 (L) | 2.7 | 64 | 172.8 | 16 | 1 | 16 | | | 4 | 0.00 | #DIV/0! | #DIV/0! | |
2P Epyc 7601 (L)** | 2.7 | 64 | 172.8 | 16 | 1 | 8 | 83269 | 645271 | 8 | 23.13 | 8.30 | 242384 | |
Ryzen 5900X (L)** | 4.1 | 12 | 49.2 | 2 | 1 | 12 | 21905 | 250401 | 1 | 6.08 | 3.94 | 115174 | |
Ryzen 5900X (L) | 4.1 | 12 | 49.2 | 2 | 1 | 6 | 44362 | 260916 | 2 | 12.32 | 3.90 | 113741 | |
E5-2683V4 (L) | 2 | 16 | 32 | 4 | 1 | 16 | | | 1 | 0.00 | #DIV/0! | #DIV/0! | |
E5-2683V4 (L)** | 2 | 16 | 32 | 4 | 1 | 8 | 64657 | 501962 | 2 | 17.96 | 2.67 | 78039 | |
Xeon Phi 7250 (L) | 1.3 | 68 | 88.4 | 8 (MCD) | 1 | 17 | | | 4 | 0.00 | #DIV/0! | #DIV/0! | |
Xeon Phi 7250 (L)** | 1.3 | 68 | 88.4 | 8 (MCD) | 1 | 8 | 127045 | 917331 | 8 | 35.29 | 5.44 | 158865 | |
i9 10980XE (W)** | 2.8 | 18 | 50.4 | 4 | 1 | 9 | 26542 | 227103 | 2 | 7.37 | 6.51 | 190105 | |
i9 10980XE (W) | 2.8 | 18 | 50.4 | 4 | 1 | 6 | 55129 | 322193 | 3 | 15.31 | 4.70 | 137290 | |
2P E5-2698V4 (L) | 1.9 | 40 | 76 | 8 | 1 | 20 | 30593 | 525002 | 2 | 8.50 | 5.65 | 164932 | |
2P E5-2698V4 (L)** | 1.9 | 40 | 76 | 8 | 1 | 10 | 53119 | 505299 | 4 | 14.76 | 6.51 | 189979 | |
Ryzen 3950x (L)** | 3.7 | 16 | 59.2 | 2 | 1 | 16 | 28609 | 432448 | 1 | 7.95 | 3.02 | 88185 | |
Ryzen 3950x (L) | 3.7 | 16 | 59.2 | 2 | 1 | 8 | 53816 | 419440 | 2 | 14.95 | 3.21 | 93759 | |
Ryzen 3700X (W)** | 3.5 | 8 | 28 | 2 | 1 | 8 | 32986 | 40897 | 1 | 9.16 | 2.62 | 76483 | |
| 4.3 | 8 | 34.4 | 2 | 1 | 8 | 24789 | 32925 | 1 | 6.89 | 3.49 | 101774 |
Dropped offline like restarted or also no internet? If just restarted can setup something like chrome remote desktop. Can even use on phone. Can also consider using smart plugs if you need to remotely power cycle a rig that is offline. I have used a combo of both for a rig i keep in storage roomI hate traveling during these challenges. Two systems dropped offline and no way to bring them back until I get home.
I remote in already. They are showing offline. Not sure if they have power or there is a network issue or they are sitting at a bios screen or what. No eyes/hands there to check. They are on different circuits so the issue is specific to the box.Dropped offline like restarted or also no internet? If just restarted can setup something like chrome remote desktop. Can even use on phone. Can also consider using smart plugs if you need to remotely power cycle a rig that is offline. I have used a combo of both for a rig i keep in storage room
