First off, I don't know if this is the right forum, so if it's not I would ask that a mod please move it.
Here is my system as it stands. I have worked a lot of this computer and it has changed a lot since I first got it. The pictures are horrible, as I just sold my digital camera.
Basically, I want to sell this and my current laptop, and move to a powerful laptop and very large display (dell 30" or 24"). If you could help me to find out what I should list these computers at that would be very helpful. Thank you!
pics:
Here are the specs:
Hardware:
Prices taken from newegg, but these things all overclock really well...
e6300 @ 3.5 Ghz @ 1.4 v - $180.00
2 GB OCZ Gold (new compatible sticks) @ 500mhz 5-5-5-15 - $235.99
Gigabyte DS3 @ 500 MHZ stock volts - $144.99
Retail BBA x1900xt running @ xtx, but on stock volts - $299.99
Audigy 2 ZS Platinum with faceplate - $50 ?
Pioneer 16x DL DVD-rw - $31.99
74 GB Raptor - $159.99
320 GB SATA2 Western Digital - $99.99
550w Antec Truepower (SLI compatible) - $75
All in a modded Lian Li v1200 Plus ($229.99) with original box.
Cooling system:
This is a self built cooling system that took a lot of care and time. I custom cut the top of the case to install the radiator, which is covered by the aquacomputer grill. Also, a delrin fillport was installed on the top of the case and connected to the T-line for an easy fill.
Radiator Swiftech MCR-220 "Quiet Power" Series Radiator - Black $39.99
CPU Block AquaXtreme MP-05 SP Limited Edition Universal $76.00
GPU Block Swiftech MCW60 GPU block $30.00
Pump MCP655 pump (Laing branded) $60.00
Tubing 7/16" ID (5/8" OD) Masterkleer $2.45
Fans YATE LOON 120mm Case Fan - D12SL-12 (Quan: 2) $7.98
Hard Drive Mounts Scythe Anti-Vibration HDD Stabilizer 2 for 3.5" HDD (Quan: 2) $13.90
Pump Block Petra'sTech "Gel-Stuff" Vibration Absorption Block $3.99
Rad Grill Aqua Computer Airplex Evo Radiator Mounting Grill - Black $31.47
Tubing 20' Masterkleer PVC Tubing 7/16" Id, 5/8" Od, 3/32" Wall Thickness $12.23
Reservoir Alphacool Mini Water Tank for Shuttle and Other Barebones + Misc $62.87
Petra Tax/Shipping N/A $17.85
Jab-Tech T/S N/A $7.58
Total $366.31
(taken from my excel sheet right before ordering)
pics:
Here are the specs:
Hardware:
Cooling system:
Total $366.31
