I started looking for some video editing software a few weeks ago and saw that adobe had released an elements version of their premiere pro. I was intrigued as it can be had for under 100$ and has much of the functionality of its big brother. I poked around and didn't find too many reviews, but those I found were very positve. I decided to go ahead an get it and started using it yesterday. So, for anyone who has been interested by this I thought I'd share some reactions to it..
I got it from buy.com for under 90$ shipped which made me happy to begin with. It comes on 2 CDs in a nice multi-disk DVD style case. It also comes with a tutorial DVD which is a nice addition as it has a bit of a learning curve. It also comes with an extensive yet extremely usable manual. For pretty much any question I've had so far, the manual has had useful, easy to find answers.
Aside from the manual, there is also a help window in the workspace which is actaully useful. The help window has a selection of topics activated which change depending on what you are working on at the moment. So, if I have the "effects" protion of the program selected, the help window has a bunch of effects related tips you browse through if needed. For a noob like myself its a very nice feature. And, when you're not using it, its very subtle and doesn't get in the way like other program assistants.
As for the program itself. It has an intuitive capture interface. If you've captred video from a DV device before you can do this.
The editing workspace is, I'm assuming, very much like Premiere Pro (though I've never actually used it). You have the standard timeline, preview window, and "tool box" which holds the effects, project media, and so on. There is a task bar along the top which allows you to select what is active in the tool box.
Importing media into a project is as easy as poking yourself in the eye. That is to say, really easy.
The effects have really impressed me. There are a ton of video effects, audio effects and transitions here. Like, way more than I'd ever use. Like other edition programs, just drag and drop an effect and its there. You can also customize most effects and transions and it seems to be pretty powerful, though I haven't played with that too much yet.
Some of the transitions didn't seem to work right at first. I followed the instructions and the effect would act goofy. Some random clicking and draggin seemed to fix this but I don't know what I did. Only a minor gripe.
It comes with a bunch of nice title templates which actually look pretty nice. Lots of fancy fonts and pretty letters to make your titles and credits look more professional. I haven't seemed to figure out how to animated titles with scrolling text and such. Not sure if I can or not. The only animation options is to make the whole template (background and all) scroll across the screen which looks really cheesy.
Thats about as far as I've gotten. And I'm very happy so far. It took about 2 hours to get comfortable using the program and I'm getting pretty functional with it now. Its extremely easy to use but looks like it will be very powerful once I learn to use more of the tools.
It also does DVD creating and, if anyone is interested, I'll report on that once I finish my project. Otherwise, for anyone looking for some good video software, this looks like a really good bet.
