Thanks,
Does the window fullscreen and Fullscreen option work in the g-sync settings. I heard only fullscreen works, or maybe I'm just making it up?
Thanks,
is it safe to leave overclock on all the time?.
is it safe to leave overclock on all the time? Also, anyone recommend a good monitor mount for this sucker? The base takes up alot of room.
Is it a fact that all X34's suffer from the scanline issue or not?
Got mine from Amazon last week (sold by Amazon, not a third party). Have not checked the build date.
Either I won the panel lottery or they are making improvements, because I have not noticed anything as severe as people have been showing or saying. No noticeable backlight bleed, no noticeable glow when viewed directly (can see some in the corners when viewed at unreasonable angles), and I've seen no scanlines so far, but I have not run Pendulum demo (I've only been running desktop applications, Fallout 4, and League of Legends). Holds 100hz overclock on G1 980 Ti. Picture looks amazing after some non-pro calibration (downloading profiles, using TFT settings, etc.).
The only real problems I have had are Fallout 4 related and trying to get Gsync to work. The monitor itself has been great for me so far.
Has anyone ever had this happen before?
A thick vertical blue line suddenly developed close to the middle of the screen. Everything looked like it had a 3D effect also, you can see it near the edges of text and UI elements. Ironically I was reading a read about QC issues right when it happened...
I rebooted back into BIOS, this was still visible there, so it was 100% on the monitor's side. Performed a reset through the OSD and that fixed it
Bizarre. I haven't had any major issues with my unit but I will probably be doing an exchange through Amazon if this happens again.
Google "line of stuck pixels".
I've never had stuck pixels before, but the images I found when I googled that looks similar to what yours looked like. From quick skimming it looks like it's something that happens, and that there are steps to fix it. So maybe it was a one time thing.
So far, so (really) good. Unit arrived a day early (which was a bit startling because we arrived back from a trip to find it on my doorstep where it had been most of the day. Thankfully we have honest neighbors).
I have some backlight bleed in the upper-left corner which alarmed me at first. But looking at the TFT-Central review, it's essentially exactly like their review sample.
Panel seems to reach 100Hz fine and g-sync is working as advertised. It's an October panel. Purchased from Amazon.
I had tried the Dell 3440x1440 curved, and the new Asus Swift IPS. I came very close to keeping both. But the lack of higher refresh rates on the Dell troubled me. . . and the Asus size of only 27" didn't feel enough like an "upgrade" for the money.
Though way too expensive (my wife is grumbling a bit), this is "just right". . . plenty large, v-sync, and 100Hz (when my Titan can push out the frames!).
This will be my last computer-related upgrade for a long while. But so far I'm loving it.
Now, I must abandon this thread lest I find issues that I'd otherwise never see. Ignorance is bliss.![]()
Acer sent Legit Reviews a monitor they pre-tested, must be nice to get that kind of service. I wish us peasants paying $1300 could get that and not have to keep returning the screen.
http://www.legitreviews.com/acer-predator-x34-3440x1440-curved-g-sync-gaming-display-review_176405
We also didnt have any issues overclocking our unit to 100Hz without any major stability issues besides the occasional scan line being seen.
The only thing I'm seeing on mine that I'm a bit concerned about is that with g-sync enabled, my mouse cursor is disappearing and/or momentarily freezing while levels load in games and the refresh rate/framerate changes (etc.). I don't recall this happening on my Asus Swift IPS with v-sync enabled.
So far I've seen this on Lord of the Rings Online, Star Wars Battlefront, and in 3DMark the top portion of the screen flickers while moving the menus (etc.).
As I posted earlier, if you have a Microcenter within reasonable distance, they will test the monitor before you drive to get it. That's what they did for me. I also got 20% off.
Saw it, must be nice to have an "occasional" scanline. I wouldn't be complaining about this monitor if that were the case for the ones I have received.They do mention the scanlines, last page...
Just received my monitor, as a replacement for my old Dell U2311.
I think my panel has major issues, but to make sure this isn't normal behavior (it's been years since I bought a new monitor), I'd like your opinion here.
I'm experiencing narrow, vertical lines on my screen, depending on what color it displays. White and pure black have no issues most of the time, while blue, yellow, gray and other colors show them all the time.
I made some pictures in Windows:
I don't think this is standard behavior, right? Should I return the monitor or is there anything I can try to fix it?
I tried G-Sync both on and off, using a DP cable (@60Hz) and a HDMI cable (@50Hz). Same results.
I waited so long for this monitor, but I'd be very disappointed if this are normal findings!
Thanks!
Okay, so this continues to worry me a bit. If not for this nagging worry, I'll probably keep the monitor. Made a video of the behavior. Would appreciate opinions about whether this behavior is normal. . . on this monitor or even other g-sync monitors.The only thing I'm seeing on mine that I'm a bit concerned about is that with g-sync enabled, my mouse cursor is disappearing and/or momentarily freezing while levels load in games and the refresh rate/framerate changes (etc.). I don't recall this happening on my Asus Swift IPS with v-sync enabled.
https://youtu.be/ItsH-SnGs4U
It's definitely less pronounced when I run g-sync in "fullscreen only" mode. And, with Handbrake (as a windows app), the behavior is absent altogether.I haven't experienced this but I run G-Sync in full screen mode only.
Acer has now posted their comments on some issues here:
http://community.acer.com/t5/Predator-Discussions/MULTIPLE-Problems-with-New-X34/m-p/406530#M2863
Basically here is what they say:
Wake from Sleep (Backlight) - Send it in for the fix
Color Banding - Send it in for the fix
Problems with Overclocking at 100hz - They say up to 100hz, so even if your monitor only does 65hz, its considered normal
Coil Whine - This is normal and not a defect according to them:
"This is caused by the strain and release of a capacitor that is designed to absorb electical charges from the powering of the device. That release from the capacitor can cause vibrations which can be audible in certain environments. This activity is considered normal and does not require any action from the user or Acer."
Scanlines - Currently being evaluated
In conclusion:
Returning this monitor next week and not looking back. Was going to keep playing the lottery but since Acer is justifying their terrible QA as business as usual, it's going back. At least Asus is marketing theirs as 100hz, I will have to just hope I never need to RMA it with them, because it will probably either be be rejected, be sent back in the exact condition or take months to complete. Sad that these are the only options so far.
2 x Titan X's SLI
G-Sync set to Full Screen Only (why would you game in anything but full screen, why??)
The X34 has been great (But I did confirm the wake from sleep black screen is there, but Ive disabled sleep).
Sucks that so many others are having problems with this great gaming screen.
Either of you guys willing to install Handbrake (video transcoding app) while running g-sync w/ windowed g-sync enabled and tell me if Handbrake causes your mouse to get jumpy as in the youtube video posted a few posts above.
I'm 99% sure this is all normal. . . but that's an expensive 1% if I'm wrong.
