PearlChoco
- Mar 28, 2011
Just received my monitor, as a replacement for my old Dell U2311.
I think my panel has major issues, but to make sure this isn't normal behavior (it's been years since I bought a new monitor), I'd like your opinion here.
I'm experiencing narrow, vertical lines on my screen, depending on what color it displays. White and pure black have no issues most of the time, while blue, yellow, gray and other colors show them all the time.
I made some pictures in Windows:
I even have it when the screens shows its boot logo or during Windows boot:
I also took this test picture for color banding:
(only the tiny vertical lines are unwanted, the curved lines are due to the picture quality)
I don't think this is standard behavior, right? Should I return the monitor or is there anything I can try to fix it?
I tried G-Sync both on and off, using a DP cable (@60Hz) and a HDMI cable (@50Hz). Same results.
I waited so long for this monitor, but I'd be very disappointed if this are normal findings!
Thanks!
Thanks!
