Precision Boost Overdrive and XFR Enhanced Confusion @ [H]
Aenra
What, more physics now? Pfft
On a serious note, i've seen mentions of PBO in the most recent Gigabyte BIOS discussions over at the official US forums, including specific BIOS versions that supposedly introduced it, subsequent ones that are now deemed 'more stable' and so on; will admit i took that for a fact as i conflated it with Asus' UEFI's similar PB2 "+"(?) functions. I thought Gigabyte's PBO was Asus' equivalent of stages (3) and (4).
My PSU is arriving tomorrow, will finally be able to have a look for myself. Am now curious to see how Gigabyte has branded their version of PB2 "+".
ACC
I just have to say that Gigabyte seems to lock their XFR2 + PBO on X370 to 140W. It could also be my air cooling limit though.
PBO setting in Gigabyte BIOS has PPT (package power tracking) , EDC (Electrical design current) , and TDC (thermal design current) as of F23D BIOS on X370.
In most usage even with cores or a whole CCX turned off it seems for my chip it hits the EDC limit first.
edit:
It's a True Spirit 140 Power but my ambient is just shy of 80°F and it's in a Fractal R5 with 2 1500RPM Phanteks PH140 MP intake. It's the X370 Gaming 5.
I have a X470 G7 but I'm waiting on DDR4 3600 C16 to do a full comparison.
Aenra
140W .. as of F23D BIOS
That's a bit low, what cooling are you employing? Oh, sorry, and which 370 mobo?
As to the latter, i have a lab rat for all of this, so starting tomorrow i can do what i never do, play around with multiple BIOSes, lol. What i want to see (as you've already answered one part, they do brand it as PBO) is the voltages; most giga AM4 boards are overboard even at stock settings. I have a lot of love for that company, but recently they've made me start looking elsewhere; looking, not heading, but.. definitely looking.
If/when you have empirical data to show, by all means do post, always helps to compare.
FrgMstr
Just Plain Mean
Staff member
From what I have seen, the Precision Boost profile that are "beyond" stock all feel like just preset overclocking profiles that are not actually using XFR2. Getting to the MSI board next.
Reactions: Aenra
FrgMstr
Just Plain Mean
Staff member
By the way can you do a measurement at the socket for each board? It seems that the software readings are completely off for X470.
dinos22 on youtube measured the Gigabyte x470 G7 and when it is 1.45V in software it is 1.4V at socket. 1.4 manual volts with turbo/extreme still are below 1.4V under load measured by Fluke multimeter at the socket. I suspect the SuperIO sensors aren't fast enough.
<1.35V all core and below ~1.425V for low load seems to be the guideline.
No. If I spent my life verifying Youtubers and correcting them, that is all I would do.
Aenra
More than understandable.
Unrelated to correcting Youtubers but pertinent to any Gigabyte mobo discussion, for those who don't know, dinos and sophos are two people whose word you can just take; for whatever they told you. Apart from no known incidents when they were (later) proven wrong, and that's rare, they're really helpful. They've also helped me personally with an X99 Designare; they're on the good side, kind of folks we need more of.
This isn't a comment on their Youtube stuff, as i don't watch it, lol. This is heads-up in case your google-ing leads you to some of their posts.
noko
This article gave me Enhanced Confusion :(
What about the non X chips? Older X370/B350 motherboards without bios updates?
Is the new PB2 and XFR supported in Linux? More a curiosity than anything else since looking at trying out Linux again.
Copyright
I'm confused.. I have seen many videos of PBO working on asus and gigabyte mobo's. There is an option to enable it in the bios. So this isn't truly PBO working?
sirmonkey1985
[H]ard|DCer of the Month - July 2010
My guess is the bpo people are seeing in bios currently is a modified WiP version amd gave out to the manufactures for testing and they just kept it there. I'd expect amd's finalized version to be more refined.
FrgMstr
Just Plain Mean
Staff member
I have a question these features you speak of are they not part of what AMD was yelling about as new and improved features in Zen+ CPU's how can they not have them enabled on launch day since they were screaming at the top of their lungs about these features in all of the slides and press events it seems a bit odd that the feaures are not working.
Edited:
I was not questioning you personally on if you were right or wrong. I was questioning as to why AMD would go on and on about these features before launch only to maybe or maybe not enable them in the future seems a bit deceptive to me if they do not fulfill on those promises.
You might need to read the article you are commenting on here. AMD had never mentioned PB OVERDRIVE or XRF2 ENHANCED publicly as part of the launch. PB2+ and XFR2, they have. I explained this fully at the link below.
https://www.hardocp.com/article/2018/05/01/precision_boost_overdrive_xfr_enhanced_confusion
Copyright
I enabled PBO (Gigabytes options) and it did run the cores harder but also was showing 1.5V+ in Ryzen Master. I turned it back off.. extra heat meant extra noise which was annoying. After this I updated my firmware and now notice my chip no longer boosts to 4.35 like it did before.. curious now if I damaged it.
noko
1.5 for a few cores for short period of time Should not hurt your cpu. I had over 1.8v on my first 1700x all the into Windows, until it shutdown which I then discovered going into the bios. In this case it did damage the cpu, I can no longer go above 1.4v now with or use XFR. Still it has been going 24/7 for the last 7 months at 3.4ghz mining at around 70% cpu usage without issue at lower voltages and clock speeds.
