PRAM battery for 12" powerbook g4 aluminum?
Calpis
I've been searching for it for the past 10hrs or so and I cant find any information on where to buy it, how to replace it, or if it even exists. The powerbook's date/time resets every once in a while so I'm sure its the PRAM...
Anyone that can help me?
the 12" powerbook doesn't have a backup battery, so you're not gonna have much luck replacing it ;) I'd try resetting the pmu/pram and go from there.
If you ever leave your computer in sleep for a long time, the battery becomes depleted and when you reconnect, your mac will lose the time and date. (Gets reset to a day in 1969). In any case, if this happens to you often when you leave the computer to sleep without AC power and the battery gets critically low, you'll lose the date and time.
At least that's been my experience with powerbooks in the past.
