Practicality of 280mm rad in Lian-Li PC-O10WX?
Discussion in 'Cases & Case Modding' started by trivial, Jun 22, 2018.
  1. trivial
    trivial [H]ard|Gawd
    1,418
    Jul 14, 2001
    Are there undrillable or un-dremel-able obstructions on the inner bottom panel of this case which would prevent using such a radiator? Everything else about it seems ideal for my first new ATX build in over 15 years, and it can even accommodate E-ATX boards: Threadripper on SFX PSU ;) (not really planning this).
  2. pendragon1
    pendragon1 [H]ardForum Junkie
    11,185
    Oct 7, 2000
    Nothing that I can see. You'll need to take the pump mount out and open some more slots and still a few holes. Should look/work good.
  3. trivial
    trivial [H]ard|Gawd
    1,418
    Jul 14, 2001
