PQI memory, what's the difference?
Solar
Browsing through newegg I came across these, aside from cost and heat spreader style, is there any difference between these 512mb sticks of PQI Turbo? PQI's websites didn't help either...
PQI3200-512SAH
PQI3200-512SBH
(cf)Eclipse
Freelance Overclocker
which would imply the other uses AH.. improbable ;)
though without question, the two probably just simply use different ram chips. which ones? i don't know.
(cf)Eclipse
the ram chips used? :p
it's probably not winbond ram though, maybe hynix, infineon or mosel ;)
Solar
there's nothing wrong with that right? You see the only things I know about memory are that the timings should be tight and 1T is better than 2T (right?). For AMD, my RAM divider is the HTT multiplier right?
Solar
thanks for that post I remember calculating these dividers some time ago but since I hadn't done it in a while that refresher was perfect, all I have to do is keep it as close to 200 as possible.
