TeeJayHoward
Limpness Supreme
- Feb 8, 2005
I encountered an issue this morning where the bossman wanted to know which servers in our domain were running 32-bit versions of Windows Server. Thankfully, he was asking a different admin, but I decided to try and tackle it on my own as well. The objective was to find every machine on our domain with "Server" in the OS version, and then I'd need to look at those machines and find the 32-bit versions. Well, Get-ADComputer can return the OS Version, but it can't tell if the machine is 32-bit or not. Get-WMIObject Win32_Computer_Sytem can tell me if the machine is 32-bit or not, but it can't tell me if it's running Windows Server. So, I wrote up a quick powershell script that would execute two commands, and combine the outcome. Unfortunately, I seem to have hit a wall, and I'm not sure what's going on. To test out my scripts, I queried a block of computers which by name. Everything worked out great. I then tried to find computers based on OS Version instead of name. RPC failures everywhere. If I run the same command outside of the script, targeting a specific machine, it works great. This tells me that there's no firewall issues, etc. The command works... When not put in a script. What gives?
This code works:
This code, however:
Just returns a bunch of RPC errors:
However, if I run the Get-WMIObject command and manually enter the server name, the results appear as desired:
If I run the Get-ADComputer command, it returns a list of servers, just like I want:
So all the individual pieces work out great. It's just when they're put together that they want to not play nice. Can someone find my goof for me?
This code works:
Code:
$GetInfo = Get-ADComputer -Filter {Name -Like "*MachineName*"} -Properties * |
ForEach-Object {
$wmi = Get-WMIObject Win32_ComputerSystem -computer $_.Name
New-Object PSObject -Property @{
'Name' = $_.Name
'Operating System' = $_.OperatingSystem
'Service Pack' = $_.OperatingSystemServicePack
'Architecture' = $wmi.SystemType
'Manufacturer' = $wmi.Manufacturer
'Model' = $wmi.Model
} | Format-Table Name,'Operating System','Service Pack',Architecture,Manufacturer,Model -Auto -Wrap
$GetInfo
Code:
$GetInfo = Get-ADComputer -Filter {OperatingSystem -Like "*Server*"} -Properties * |
ForEach-Object {
'Name' = $_.Name
$GetInfo
Code:
Get-WMIObject : The RPC server is unavailable. (Exception from HRESULT: 0x800706BA)
At C:\arch.ps1:3 char:16
+ $wmi = Get-WMIObject Win32_ComputerSystem -computer $_.Name
+ CategoryInfo : InvalidOperation: (:) [Get-WmiObject], COMException
+ FullyQualifiedErrorId : GetWMICOMException,Microsoft.PowerShell.Commands.GetWmiObjectCommand
Code:
PS C:\Windows\system32> Get-WMIObject Win32_ComputerSystem -computer HAL
Domain : contoso.com
Manufacturer : HP
Model : ProLiant DL380 G6
PrimaryOwnerName : Windows User
TotalPhysicalMemory : 25759043584
Code:
PS C:\Windows\system32> Get-ADComputer -Filter {OperatingSystem -Like "*Server*"} |Format-Table Name
Name
HAL
<snip>
