Hi, so i eventually bought an RX470 after asking 1 million questions.
I want to get another one BUT the price has spiked a bit now sure if i must consider the ASUS 470 Strix 6 pin connector card and or the Giogabyte 480 G1 8 pin connector card.
Those seem to be more affordable ....
I just hear they run very very hot... the PowerColor i have also runs very hot, i suppose they all do.
I think my questionS are really , is it safe to buy a second card online at sites like amazon.co.uk or amazon.com?
Or is it better to just buy a new card and spend the extra 20-25 pounds?
Do you just close your eyes or is this something you should really try to work on and get a good deal on?
I mean for my case yah i need to save because i am using my savings to buy this stuff.
I do not mind buying a second hand/used card for 150 versus 175/180 pounds...
Only problem for me is i do not live in the UK or the US or CHINA or PHILIPPINES or UAE so i need to be mindful of shipping.if it is broken.
My next question is more about the brand, between the Gigabyte 4GB G1 (8pin connector) and the Asus Strix 4GB (6 pin connector) which would you prefer or doesn't it matter because they all get hot and work pretty much the same?
My next question is , i have an old i7 2600K CPU i think the motherboard i have is rubbish maybe becuase it is not a good overclocker.... at least when i change the multiplier from 34 to say 36 i dont see bugger all CPU speed improvement when i use say Minergate to mine AEON coin..,..its the same bloody speed.
Do i leave this processor or do i get a new socket Intel board OR even 1366 2011? i dont know....
I also have an AMD X4 860K not a bad CPU for mining, but it is half as slow as my i7 2600K
Not sure if it is worth the energy and selling the Intel and AMD platforms each individually CPU and MOBO and then buying a new platform.... again i am not sure which is a better deal here for mining...
Intel or amd ... is Ryzen just a huge hype right now?
i dont know....seems like alor of work to focus on motherboard and cpu also.
But it makes sense if i want to just use one machine for mining? i
