power supply recommendations?
tsubasa hanekawa
hello all, im planning a new build soon due to having to change some things around but im not so sure which way to go with the PSU, the extreme PSU calculator says around 804W peak usage (so 100%) and 729W at about 90% (this is with a 6990 on the list bare in mind as i may be acquiring one cheap) so, from this what's my best option PSU wise? would i be able to get away with a decent 850W from seasonic or would that be cutting it a bit fine?
spec wise it's 2 opteron 6272's, a supermicro H8DG6-F, im planning on filling up all the ram slits eventually, a 7950 to start with (then maybe a 6990 or perhaps just a second 7950), few fans along with 2 HDD's and one SSD
tsubasa hanekawa
i've moved this over to the power supply section and am not sure how to remove this post XD im a noob on this forum, not so much in hardware just the forum :p
budget is £130~ though
Nathan_P
[H]ard DCOTM x3
Get a corsair HX or seasonic 750 or 850 w PSU from scan, dabs or overclockers and be done with it
