D
Deleted member 88227
Guest
Anyone know where I can buy a plate that uses the standard PSU plug? I intend to install two PSUs in a very large case, but I don't have room for the second power supply to have it's own "window" so it will be completely inside the case. I want to install some sort of short extension inside the case that allows me to unplug/plug that PSU from outside the case.
I found plenty of extensions, but there is no way to mount it securely to the case which is what I want to do.
Any ideas?
Any ideas?
