Power supply going bad? (Asus power surge detected, cpu fan going up and down quickly
Stiler
Earlier today out of the blue my computer just randomly shut itself off, when it came back on I had a message come up on my screen:
"Power Supply Surges detected during the previous power on.
ASUS Anti-Surge was triggered to protect system from unstable power supply unit!""
After the first time this happened my computer came on just fine and I didn't think much of it, just a random thing.
Then later tonight my computer was in sleep mode, I came back and hit a key to bring it out and it did this again.
However after this now my CPU fan is just constantly revving up for a few seconds (about 15) then it slows back down, then it revs right back up, over and over and over.
After this started I shut off the pc and opened it up, made sure all the connections from the psu were on, the cpu fan>cooler>motherboard were in, etc.
I googled the Asus power surge message and see a lot of people saying it's overly sensitive and to turn it off, however this was the first time I have got this message (had the computer about 3 years).
My specs are:
Asus z68-v pro gen 3 motherboard
H100 cooler for psu w/ gentle typhoons in push/pull
Corsair HX 850w PSU
Intel 2600k
8gb ram
I have tried to see my temps/fan, speedfan seems to have a problem with my motherboard (I can't control the fans with it) but the cpu fan I can see from the chart in the monitor of speedfan keeps going from 3500rpm to 3800 over and over and over.
I then tried HWmonitor to look at temps, the cpu cores are reporting all around 30c for temps and the voltages are saying 0.9-1.2 (min/max).
I just can not figure out why my cpu fan keeps revving up and down up and down, it's driving me nuts.
Any help would be greatly appreciated.
edit - I just downloaded and used the Asus suite tools (those are supposed to work for my mobo) and it's reporting that the 3.3 rail is at 2.94, is that a bad thing? A sign my psu is dying?
Sith'ari
1) I googled the Asus power surge message and see a lot of people saying it's overly sensitive and to turn it off, however this was the first time I have got this message (had the computer about 3 years).
2) I have tried to see my temps/fan, speedfan seems to have a problem with my motherboard (I can't control the fans with it) but the cpu fan I can see from the chart in the monitor of speedfan keeps going from 3500rpm to 3800 over and over and over.
3) edit - I just downloaded and used the Asus suite tools (those are supposed to work for my mobo) and it's reporting that the 3.3 rail is at 2.94, is that a bad thing? A sign my psu is dying?
1) & 3) : You are giving the answer yourself !! You have the same system for 3 years and only now it appears the Asus powersurge message, so it's not a matter of sensitivity of the software. Also the 2.94 voltage at 3.3V rail, it's a huge deviation from normal !! :eek:
So these 2 combined, makes me certain that you must change your PSU !!
2) About the speedfan i can't tell you, maybe it's related with the PSU problem or maybe it can be fixed from Asus's mobo utilities software.
EDIT: Do you have a UPS or the power passes directly from your PSU? If you have a UPS, then the problem could be related with the UPS also.
ythe1300
The best thing to do is grab a multimeter and test the voltageshttp://en.m.wikipedia.org/wiki/ATX#Power_supply
Does sound like you need a new one though.
Araxie
try powering off the PSU switch, then disconnect the PSU from the power outlet let it rest more or less 30-45 min. and plug again.. sometimes PSUs need to reset some dirty energy from the circuitry, that help.. do not trust in software voltage readings grab a multimeter and test yourself 3.3v 5v and 12v..
Stiler
Yeah thanks for the tips, I ended up getting a new Seasonic psu and the problems stoped.
Sending the Corsair in to RMA for refund.
fantomau
i just got that same error msg today
psu is a corsair ax850
