When attempting to play a new blue ray I just bought, Taken 2, I get the following error:
1. Dialogue box that says "Cyberlink Power DVD cannot access the storage device. Select another device when playback stops"
2. After I push the OK button, I get a dialogue box that says "This is your first time playing a BD-Rom title. You need to select a region for BD-Rom playback, which you may select up to 5 times. Select one below, then click OK." Below that, is a region code selector, which gives you the option to check from 3 regions (A, B, C which I take it is pretty standard)...there is also a counter which shows how many times you have left to select a region, and this is set to 0 times left.
3. After messing with that for awhile (and failing to select a region). I am greeted with a dialogue box that says: code 800401f9 than says error in the dll.
Somw quick facts:
a. have the latest version which is 3318
b. I've already done the uninstall, then reinstall with no results.
Can someone tell me exactly what is going on?
Somw quick facts:
