Power consumption between 290x and 580
Discussion in 'Video Cards' started by ELox, Aug 4, 2018.
  1. ELox
    ELox Limp Gawd
    336
    Jan 31, 2008
    Recently had my 290x die on me and have thrown in a 270 for now to get by.
    I was looking in the used market locally and saw a MSI rx 580 4gb oc armor for $280 Canadian ( looks like it’s $380 CDN brand new). Seems like a decent deal but I just want to make sure it won’t use more power than my old 290x did. It looks to me like the 580 might actually draw less power but I wasn’t looking at side by sides so a confirmation would be great.
    Bonus Question: the 270 is actually playing what I need it to these days (by turning the settings down) so would it be better to just hold off? Haven’t been paying attention to the market as I wasn’t planning on a new vid card purchase.
  2. Neapolitan6th
    Neapolitan6th Gawd
    646
    Nov 18, 2016
    If you can make do, make do. If you need the performance, then go ahead.
    I would at least hold out until something like a new game comes out that you've been looking forward to.
    That said, the used market right now can be pretty enticing. If you find a good deal, jump.
    Otherwise, there will always newer cards to be had if you choose to wait.
  3. N4CR
    N4CR 2[H]4U
    2,611
    Oct 17, 2011
    I'd hold till ngreedia launches if you can. Might make a Vega or 1080 or 1070 closer to your budget. They've already hit 425 new for v64s. Bit more power but far bigger performance jump.
    580 will use less power than both though and be similar perf, memory access intensive games may give the 290x an edge though with dat phat bus.
    Sulphademus likes this.
  4. misterbobby
    misterbobby 2[H]4U
    3,243
    Mar 18, 2014
    I dont understand why you would even have to wonder such a thing. Literally a few seconds of research would show the 580 uses no where near the power of the 290x. The 290x was a very power hungry high end 290 watt card and the 580 is a 185 watt mid range card.
    Maddness likes this.
  5. ELox
    ELox Limp Gawd
    336
    Jan 31, 2008
    Thanks for the quick replies and confirming what I saw when I did a hasty search on power consumption. Sounds like the mining market might be turning a bit of a corner and there’s some new cards on the horizon so I think I will run the 270 for a bit.
  6. FlawleZ
    FlawleZ Gawd
    537
    Oct 20, 2010
    I just bought a 2nd hand Sapphire Nitro 580 8GB here for 220 shipped. No way I would pay 280 for a 4GB.
  7. brucethemoose
    brucethemoose Limp Gawd
    236
    Mar 3, 2018
    Used 980 TIs are where it's at, IMO.
    Near Vega/1070 performance, but I grabbed one for $320 almost a year ago. And it has enough VRAM to age better than a Fury X (which is almost impossible to find used anyway).
  8. sabrewolf732
    sabrewolf732 2[H]4U
    3,695
    Dec 6, 2004
    wait till nvidia launches so you can get a vega56 which is actually an upgrade.
  9. wrangler
    wrangler 2[H]4U
    4,021
    Jan 17, 2005
    Just a side note...
    I'm currently upgrading an Ivy Bridge office machine for a kid to have a gaming computer.
    Today is stress test burn in day.
    Stuck a 270 in it that I had collecting dust in the closet and I have to say... It still does pretty well.
    CPU is a 3570S.
    Granted the monitor is 1600x900 but it is chewing up everything I throw at it on high or medium.
    Warm fuzzies.
  10. ELox
    ELox Limp Gawd
    336
    Jan 31, 2008
    Used markets can vary quite a bit depending where you are. I suspect you missed the two references to Canadian dollars in the OP.
  11. rtangwai
    rtangwai [H]ard|Gawd
    1,299
    Jul 26, 2007
    ELox, where in Canada are you? I've seen offers for RX580 8GB for $280 CDN used in the Toronto area.
    Having said that, if the 270 is holding up for you and you can wait then you shouldn't buy at all right now - new cards will eventually arrive, the longer you can hold out the better.
  12. ELox
    ELox Limp Gawd
    336
    Jan 31, 2008
    I’m over in BC and about 5 hours from Vancouver so there’s not much in my area in the used market. Thanks for the advice.
  13. Droppinbodies
    Droppinbodies n00bie
    9
    Jul 29, 2018
    in most cases the 580 will be slightly better
  14. Lonewolfff
    Lonewolfff n00bie
    1
    Nov 16, 2017
  15. FlawleZ
    FlawleZ Gawd
    537
    Oct 20, 2010
  16. barongan
    barongan n00bie
    2
    Jul 30, 2018
  17. Droppinbodies
    9
    Jul 29, 2018
