power color rx580 8GB $199 @ newegg
Discussion in '[H]ot|DEALS' started by Deleted member 93354, Jul 14, 2018.
  1. Ocellaris
    Ocellaris Ginger @le, an alcoholic's best friend.
    18,837
    Jan 1, 2008
  2. Ugh
    Good catch. Dvi will still support 2k. But looks like this one is designed for people who mine
    MrC4 likes this.
  3. IdiotInCharge
    IdiotInCharge [H]ardForum Junkie
    11,952
    Jun 13, 2003
    I have four monitors on my desktop... and I could probably make use of a fifth.
    One 2k output? This card shouldn't even be listed with regular GPUs...
  4. doublejack
    doublejack Limp Gawd
    446
    Apr 13, 2015
    This GPU is pretty clearly made for mining. As has been pointed out there is only the single video output, and it is DVI of all things. Then check out the clock speed. The GPU comes running at 1215MHz. That is really slow for an RX 580, It is 51Hz slower than reference RX 480s. So, out of the box this card comes somewhat tuned for mining in an efficient manner.
    It looks like this is a mining sku that hit the market too late, or that some Chinese plant was making for miners all along and the demand has dried up.
    I don't think this card is worth $200. I would not even pay $150 for one. My view may be a little skewed, though, because I just picked up a PowerColor Red Devil RX 580 8GB for $140 yesterday (craigslist sepcial).
  5. Sodapopjones
    Sodapopjones [H]ard|Gawd
    1,855
    Aug 22, 2012
    The Korean monitor special.. :ROFLMAO:
  6. GilmourD
    GilmourD [H]ardForum Junkie
    11,186
    Jun 17, 2004
    I was so tempted by the price I didn't catch that at first. That would suck for me since I've got a multi-monitor setup. Welp, forget that one!
  7. YeuEmMaiMai
    YeuEmMaiMai [H]ardForum Junkie
    15,326
    Jun 11, 2004
    so what? it will work as a second card in crossfire
    Eshelmen likes this.
  8. Eshelmen
    Eshelmen [H]ardness Supreme
    4,319
    Feb 3, 2004
    Wait, what? Why in the hell would this only have a DVI port? No hdmi on 2018 mid range card? Wth is that all about?
  9. kinjo
    kinjo [H]ard|Gawd
    1,053
    Dec 17, 2010
    Mining card the soldered a DVI onto after the crypto market crash.
  10. MrC4
    MrC4 [H]ard|Gawd
    1,309
    Feb 10, 2010
    At least go with hdmi or displayport if you are only going with one port for the US market.
    Sulphademus likes this.
  11. Master_shake_
    Master_shake_ [H]ardForum Junkie
    9,700
    Apr 9, 2012
    Great card for people stuck with older cards and just have a single 1080p monitor
  12. Verge
    Verge [H]ardness Supreme
    6,296
    May 27, 2001
    They need to upgrade monitor first IMHO.
    Cards will continue to get cheaper... fix the other bottleneck.
  13. Sodapopjones
    1,855
    Aug 22, 2012
    I wouldn't call a monitor a bottleneck, if you have a Korean monitor this is a non issue, and there's not much reason to upgrade from one, unless you realllly have to have adaptive sync... I also don't see the point of buying an expensive monitor if you don't have the card to run it, but to each their own.
    GoldenTiger and iRevert like this.
  14. GilmourD
    11,186
    Jun 17, 2004
  15. Ocellaris
    18,837
    Jan 1, 2008
    It was $209 when he linked it. No rebate either.
    GilmourD likes this.
  16. Sulphademus
    Sulphademus Limp Gawd
    354
    Mar 18, 2010
    At least with DP you can daisychain.
  17. doublejack
    446
    Apr 13, 2015
    Even if someone is staying with a single 1080p display, there is a very solid justification to upgrade it - freesync.
