If gaming is your primary concern and you want the best you can get, then you might consider asking the AMD guys over there about some solutions they can hook you up with (Not that we can't, but the Intel forum is for Intel builds IMO). That said, both processors you have picked are good - but for varying reasons.soxfan894 said:Alright....Ive been ready all over the forum and Im still stumped....
Im building a new comp.
I dont know if i should put the P4 D950 or the P4 Prescott 670 3.8ghz
system will be used for gaming and dvd stuff, but more for gaming
Unless I should scratch the Intel idea and go with AMD????
The Pentium 4 670 3.8GHz will offer a better gaming experience (Due to its higher clock speed mainly) in games that are not multithreaded-capable.
The Pentium D950 will offer a fluid desktop experience and the ability to multitask far better than the Pentium 4 670, and will still offer a competitive gaming experience. Rather expensive though, and most tend to buy a lower end Pentium D 9XX (930) and overclock it to D950 speeds easily with stock cooling, thus saving you money on your purchase.
The reality is that contrary to popular !!!!!! belief, even an Intel 3.4GHz can offer a solid gaming experience amongst many other things - although AMD will offer you the superior gaming experience for your money. If you're dead set on Intel - I would suggest overclocking a Pentium D930 or similar model to the same speeds you're seeing, since the word is that it's pretty easy. But for the raw game performance when the game isn't multithreaded-capable, the 3.8GHz is likely to come out on top. There are other things like the better cache on the D9XX (Speed-wise) to take into account but generally, I do believe the 670 will do better in gaming. The D9XX will provide a fluid computing environment (With a significant boost over the 670 when the game is multithreaded) and still deliver a solid gaming experience.
