MalfurionStormrage
- Feb 15, 2005
I saw this thread and figured it's as good a place as any to ask this question.
I've been debating between an AMD versus Intel system for quite some time. I recently decided that if I went PCI Express I would stick to the Intel side of things (the nForce4 and VIA KT890 chipsets are too buggy for me).Well, the situation is that my best friend just bought me a brand new ASUS EN6600GT PCI Express video card. Now, I don't have the biggest budget in the world so I don't want to go into the 925x/xe chipset, leaving the obvious choice the 915 chipset.
I want to stick with ASUS. My first and last motherboards were ASUS and I've never had any problems with them. My wife's (former) MSI was a piece of crap and one of my other friend's Gigabyte board has loose capacitors on it from the get go. So, please only ASUS motherboard recommendations.
Now, the questions:
1) ASUS makes a 915 DDR motherboard. How badly will DDR slow the system down if I never consider overclocking and exceeding an 800 MHz FSB?
2) ASUS also makes a 915 DDR/DDR2 motherboard. What exactly is compromised by having DDR/DDR2 support on the same motherboard other than only two slots available for each memory type? Is the performance worse? Anything else I should know about?
I am trying to keep the motherboard/CPU price below $400. I'd like to eventually purchase a 64-bit processor but it's not important to have that initially -- I have to have something to upgrade to in the future. I bought my wife a 3.2 GHz 478-pin chip for her Sims 2 computer knowing that 478 is EOL. I'm very happy with the performance of that chip and would like to get the 3.2 GHz in the LGA 775 package.
I have 2x512 matched Micron DDR266 PC-2100 RAM from my wife's old system. It is because I have this RAM that I am even considering the DDR/DDR2 board.
Given the above, what would you do?
EDIT: No one needs to speculate on this any more. I am going DDR only on this board so I ordered an ASUS 915/DDR board. I'll just replace the cpu/mobo in 12 to 16 months and give my wife the extra gig of ram.
Now, the questions:
