Very nicely done! Any plans to WC the GPUs in the future?
Very clean, but MASSIVE overkill on the PSU lol.
german muscle - is that top mounted rad blowing warm air through it and out? or reverse of that?
Need some suggestions for cable management in my gf's machine. Case is an NZXT Source 210 and PSU is a CoolerMaster eXtreme Power Plus RS-460.
http://i39.tinypic.com/2mn5dts.jpg
Excuse the wire leading out of the case, it's connected to the side panel fan.
I agree. I'm planning on making one.^ you should get a 24pin connector in blue too. Other than that it's great.
Looks pretty neat, stock cooler fan wire could be better hidden by coiling it underneath rather than running it around like that but that's the only thing that stands out to me. GPU power could be pulled taut too. Multiple displays have long kept AMD cards from idling fully, dunno if it's the same deal for NV.
I disabled multiple displays, and temps dropped about 20c within a few minutes. I guess it really needs to work quite a bit harder to power 2 displays. What do you mean coiled underneath? Remove heatsink and shove it underneath? I was thinking I could turn it 180 degrees but I hate putting the locking the heatsink to the motherboard.. it requires a bit of pressure thats best dont with the motherboard out of the case. I will pull the GPU cable tighter, and see if I can run the front audio connector behind the power supply.
Id personally leave the 2 cards in. Sure, it idles higher, but the load temps wont change too much.
And yes, its true, 2 monitors does cause idle temps to jump 10-15*c on well ventilated cases. Since your case isnt very friendly to higher end parts, it makes sense yours rose 20*c.
If you didnt already sell the other 560, I would slap it back in there.
Temperature is the same with side panel off. The temps dont have anything to do with dual cards. 1 card by itself idles at 58C with dual monitors. Disable dual monitors, and temp drops to 38C within minutes.
I sold the second 560 because I would rather have 200 bucks in my pocket than slightly higher graphics settings.
Nice job, sometimes people make light of how easy it is to hide cables in newer cases but that looks like it took a good deal of work.
Thanks!
It took a bit of time, of course, but not a huge amount of time. Only a couple hours or so.
I can understand the sentiment that clean cabling is easy, though. Almost all full tower cases have plenty of cutouts to route cables through and ample space between the motherboard tray and back panel to hide others. Even some mid towers have a limited amount of them. So, in comparison to the not so distant past, having clean cabling is a fairly easy thing to attain, as it that requires only a bit of effort and a couple hours of time. To say that it's effortless is an overstatement of the ease, however.
Now, clean cabling in cases without any cutouts and limited space behind the mobo tray? That requires a more sizable amount of time and effort!
I generally agree--my older cases are fairly obnoxious to deal with for wire management, because there are no/barely any cutouts and not a lot of clearance between the back of the mobo tray and the side panel. New cases have a lot of exciting holes and spaces.
Either way, your wire job is awesome, and obviously took a lot of effort--nice work.
Until I get my 680s and put them in the loop
