BeavermanA
- Apr 27, 2006
And the lol shot:
looks really nice although that 800D looks so empty lol
heres my cables
modded h50 woo wooo![]()
heres my cables
@ Deff:
I think it looks good, but what's going on with that red SATA cable?![]()
Its getting replaced![]()
I only had two black SATA cables on-hand, and my local comp store doesn't seem to carry black cables![]()
yeah i dont really understand the modded h50 above. i can see modding it to add in a different/bigger radiator, or to add a flowmeter or temperature sensor, but whats the point in modding it and just adding a reservoir? seems like it just makes it more complicated with no actual added usefulness. :/
Did the temperatures decreased by adding that reservoir to the H50?
With extra liquid your temps will stay a little more stable. After hours of running at load, ultimately it would eventually reach the same temps with or without the extra liquid, but because there is more, it will take more time for it to heat up (and also cool down.) If your system only peaks its load in little spikes, there is some benefit, as they will be even more smoothed out, and temperatures will remain even more constant.
Heres another PC- A05 build.
thats really cool. glad it helped your temps. idk if id have been willing to try that. how did you attach the hose to the h50 and res? does it have barbs of some sort that you could reuse?
yeah they both have 1/4inch barbs so that was easy to work with.
i mean you can get the H50 for $50, the microres costs $20 and the tubing and barbs for the res cost $10 so its not a huge investment.
snip
man, those obsidians just make it way too easy. nice build! (needs Xfire though)
Spiko - That would look alot better if the video card cables ran over the top of the video card. Also, this will help with the airflow to the gpu fan.
cygnusx-1 - Have you noticed any better temps when the radiator is positioned that way instead of with cables on bottom? Never though about it but maybe that would help flow.
My first complete custom build and with cable management. Found out that the Antec 300 doesn't offer much room in managing cables, I was able to do something though. Here we go.
*snip*
