Post your "rate my cables" here
Discussion in 'Case Mod Gallery' started by DRJ1014, Aug 10, 2004.
  1. OofC_S7v7N
    OofC_S7v7N Gawd
    723
    Apr 9, 2007
    Is that fan on the bottom 100% necessary, and two what is the controller doing outside the case?
  2. palmboy5
    palmboy5 Limp Gawd
    315
    Oct 19, 2006
  3. drew630
    drew630 Limp Gawd
    306
    Jun 27, 2008
    Probably not, but the fan is blowing in/ sucking in air from the bottom which, if anything, doesn't hurt. Plus it has blue led's on it and I can always use more lights. :D
    The controller goes on the door panel. I have 2 addition cathode's on the door. Because the fan on top of the case is as wide as the case, the only way I could get a cathode up there is on the door. Since the door is off, the controller is just sitting there. The other controller for the 2 other cathode's (the ones actually pictured) is below the HDD bays. Yes, I like a lot of light. :D
  4. Traumatica
    Traumatica n00b
    26
    Jan 5, 2009
    mini P180 and non-modular PSU = nightmare.
    Here's my attempt:
    [​IMG]
  5. OofC_S7v7N
    OofC_S7v7N Gawd
    723
    Apr 9, 2007
    The fan just looks funky down there like that maybe a bigger fan would "help".
    And the mini p182 guy that looks like trick photography to me.
  6. drew630
    drew630 Limp Gawd
    306
    Jun 27, 2008
    Yeah, the space is designed for a 120mm fan (the one is picture is only a 80mm) and I will probably include a 120mm in my next Newegg order. I just had the 80mm laying around and figured why not put it in.
  7. fender
    fender Limp Gawd
    417
    Mar 2, 2003
    Before:
    [​IMG]
    After:
    [​IMG]
    No, they're not mixed up. The first shot was after my initial attempt at cable management in an unmodified Antec 900. While it looks a lot better than the second, it would have been way too impractical for me. I would have had to unscrew the power supply and disconnect almost everything just to fully remove the side panel. Also, the other side panel was practically bulging from all the cables I had tucked in there.
    All in all it was a bunch of time wasted to end up to where I was before. I also sleeved the fan and case cables, but it's not like that makes it look any better with power cables all over the place.
    So my advice is to think twice before you attempt to redo your case's cabling.
  8. epicjas0n
    epicjas0n Limp Gawd
    261
    Mar 5, 2009
    Just added my new Sunbeam fan controller and an old 120gb hard drive I recently recovered.
    Before:
    [​IMG]
    After:
    [​IMG]
    Closer look at my IDE cable folding:
    [​IMG]
  9. voklskier4452
    voklskier4452 [H]ard|Gawd
    2,029
    Nov 20, 2008
    here is mine i think i did a fairly good job.. this used to have a thermalright true black edition before i moved to watercooling and an ATCS 840
    [​IMG]
    here is the new ATCS 840 with watercooling... and i have plans to make the cables much cleaner
    [​IMG]
  10. THERMAL-REACTOR
    THERMAL-REACTOR n00b
    53
    Nov 27, 2008
    Cleaned my wiring up a bit more here`s a new shot:
    [​IMG]
  11. Omerta
    Omerta [H]ard|Gawd
    1,540
    Mar 12, 2008
    Hey thermal-reactor, what exactly is that bracket on top of the 24pin connector? Anyhow, it doesn't get any better than your cable management in that case.
  12. THERMAL-REACTOR
    53
    Nov 27, 2008
    It is the spare fan shroud modified. It works perfectly and looks like it was made to fit that space.
  13. OofC_S7v7N
    OofC_S7v7N Gawd
    723
    Apr 9, 2007
    Some how thermal that looks very clean for the amount of stuff you have packed in there. Very nice;)
  14. THERMAL-REACTOR
    53
    Nov 27, 2008
    Thank you guys for your comments. I have plans for water cooling with my next setup and will for sure make a worklog when I do.
  15. OofC_S7v7N
    OofC_S7v7N Gawd
    723
    Apr 9, 2007
    I will be looking for that work log if you do get one up.
  16. crazyjeeper
    crazyjeeper [H]ard|Gawd
    1,831
    Aug 31, 2008
    I just redid my cables and installed the TRUE.
    [​IMG]
  17. OofC_S7v7N
    OofC_S7v7N Gawd
    723
    Apr 9, 2007
    crazyjeeper will that 8 pin not reach under the motherboard tray?
  18. mekkanic
    mekkanic Gawd
    925
    May 14, 2007
    thermal reactor nice rig and nice cable management.... :)
  19. crazyjeeper
    1,831
    Aug 31, 2008
    Nope, it is actually really short. I need to go get an extender, but until then, that is the only way to make it reach the connector.
  20. lord_farfig
    lord_farfig [H]ard|Gawd
    1,410
    Jun 3, 2004
  21. faugusztin
    faugusztin 2[H]4U
    2,653
    Mar 9, 2008
  22. kenprescott21
    kenprescott21 Limp Gawd
    248
    Oct 13, 2008
    :( Pretty much as it sits right now.
    [​IMG]
  23. mrmylanman
    mrmylanman [H]ard|Gawd
    1,484
    Jul 13, 2008
    Your wiring is cleaner than what I had when I had my motherboard "open bench"
  24. TraitorJackKnives
    TraitorJackKnives n00b
    47
    Mar 2, 2009
    Great wiring job, case looks nice too.
  25. Jodiuh
    Jodiuh [H]ardness Supreme
    5,275
    Feb 3, 2004
    So...yeah. Putting in the carpeting proved to be a bitch. Reversing the drives kept me up even longer. But damn if they aren't cooler by the circuit boards and the high pitched variable whine from the raptors has disappeared! There's a 3 ring circus of SFLEX in the front too. Everything stays chilly and it's fairly quiet. Just a few more cables to mesh and tidy here and there, but that'll have to wait for another day. It's time for some GIZ-AIMING! Steam, L4D, go!
    [​IMG]
    Yes, that is a Fuji apple. Where have you been all my life? These things got packed w/ sweetness. If you haven't tried one, get on it. Or a honey crisp if your budget can swing it! :eek:
  26. Reza
    Reza Limp Gawd
    442
    Sep 13, 2008
    Oh i just thought you were a Deathnote fan. :rolleyes:
  27. Pharoahe808
    Pharoahe808 [H]Lite
    105
    Nov 20, 2006
    Your cabling looks very very good. Nice carpeting too.
  28. kookoo102
    kookoo102 Limp Gawd
    455
    Mar 4, 2009
    Any Comments would be nice. especially any ways to improve the overall look.
    Well here is my setup.
    Setup: (no oc at all)
    CM CosmoS
    Asus M4N72-E
    AMDx4 9650
    G.Skill 4gb (dual @ 1066)
    Thermaltake 850w PSU
    BFG gtx 260
    Creative Sound Blaster X-Fi Titanium
    Dlink Xtreme N Desktop Adapter
    WD Black series 1.0GB sata (32mb) HDD
    Pioneer sata DVD-RW
    Cooling:
    Arctic Cooling Freezer 64 Pro 92mm CPU Cooler (40cfm)
    3x Top Coolermaster stock style 120mm fans (44cfm)
    Front 120mm Antec blue led fan (79cfm)
    Bottom 120mm CM stock style fan (44cfm)
    Rear 120mm CM red led fan (44cfm)
    Side 230mm CM fan (150cfm?)
    ZALMAN MFC1 Plus-B 6 Fan Controller
    Any comments are welcome!:)
    [​IMG]
  29. SDMorris
    SDMorris Gawd
    675
    Jun 12, 2008
  30. elite.mafia
    elite.mafia Broke Back [H]
    11,564
    Aug 23, 2004
    So fucking random ROFL
    :p
  31. Cambo
    Cambo n00b
    59
    Jun 18, 2008
    [​IMG]
    [​IMG]]
    [​IMG]
    I will be sleeving the ATX power and buying an extension for the 12v P4 power and sleeving that as well as soon as i figure out how to remove the pins from the connector. I tried for a long time, no luck.
  32. kookoo102
    kookoo102 Limp Gawd
    455
    Mar 4, 2009
  33. SDMorris
    SDMorris Gawd
    675
    Jun 12, 2008
  34. KissOfDeath
    KissOfDeath [H]Lite
    81
    Jan 15, 2008
    lol... wish i had a good cable managment like u guys.... :D
  35. kookoo102
    kookoo102 Limp Gawd
    455
    Mar 4, 2009
    post it up.. maybe there are things that can be done :)
  36. guywithFX
    guywithFX Limp Gawd
    133
    Mar 18, 2004
    After staying up all night and finding this thread after about 2 years off [H], it inspired my to do some cable management after installing my new 4870. This is what I did with just routing cables and no zipties in my dorm room.
    [​IMG]
    [​IMG]
    God my case is huge :D Love it though, and on my 4th build in it to boot!
  37. kookoo102
    kookoo102 Limp Gawd
    455
    Mar 4, 2009
    DAMN you have room to spare! how about some watercooling?:D
  38. SDMorris
    SDMorris Gawd
    675
    Jun 12, 2008
  39. guywithFX
    guywithFX Limp Gawd
    133
    Mar 18, 2004
    Ya, well it was watercooled back when I had my P4 about 5 years ago with the original DD MAZE4. I ended up getting all ZALMAN'd up on my last AMD X2 build cause I was going for silence. I'd definitely like to go back to watercooling this summer. Havent had time as I upgraded to my C2D setup only a week before moving to Canada for school.
    I do love that the loudest thing in the case is the hard disk. Reminds me that i need to invest in some sound insulation.
  40. OofC_S7v7N
    OofC_S7v7N Gawd
    723
    Apr 9, 2007
    Is there really that much of a demand that they made the x58 for the microatx?
