I like th internal USB drive for readyboost, how's you jerry rig that in there?added some stuff ... ghetto rigged a USB flash drive internally for readyboost (was spare crap), and used an IDE->CF adapter for an old 1gb CF card I had. Backup all my major sensitive data to that as well as my external.
Cheers!
Where did you obtain those feet?![]()
^^^Not bad.![]()
Cheers!
I LOVE the "DAMN IT" button! I'm cracking up! Where did you get that and what does it do?
New rig, new case
ttp://xs412.xs.to/xs412/07082/PICT0657-1000.jpg
http://xs412.xs.to/xs412/07082/PICT0658-1000.jpg
It was suprisingly hard to wire with lack of room behind the mobo tray, so i bought oom to make the wires i couldnt hide look better :]]
What'dya think?
I'm back!!!
Currently moderating a forum with a very close friend but decided to mosey on back for some casual [H] posting to fill in the free time.![]()
I was hoping a few people were still lingering around here from before...I won't take up too much cable picture space though...get on it people...the master's back.![]()
sup corn...the v1000 still looking good?
lol. yo wat temps u getting @ that V? cause i want to do 3.0ghz but i can do 2.8ghz @ 1.55 and im too affraid to go to 1.65V. wat cooler u have?
Do you have the ability to turn those drives around...that's really killin' it for me.
Aside from that...most of the front case leads/USB/FW cables down below could easily be stuffed up underneath the motherboard, and would clean up the messiest looking area in the case.
For a pre-built that loop and wiring is pretty clean.
As for the case leads, I'll see what I can do about stuffing them under the motherboard. I'm also thinking about getting rid of the D-bracket and it's ugly beige wiring.
Not the cleanest setup, but not too shabby for having 4 hard drives and a outward facing hard drive bay = )
What do you guys think?
(Edit: Tinkered around a little bit more. Posted updated pics)
http://www.freewebs.com/anewprelusion/fullopen2.jpg[IMG]
[IMG]http://www.freewebs.com/anewprelusion/hdbay2.jpg[IMG][/QUOTE]
which fans are those on the hyper 6+?
Good stuff....those things haven't made their way into any of my cases in a VERY long time. Get some new pics asap.![]()
I updated my original post with new pics. Changed the SATA wiring and got rid of the dbracket and firewire cables. As for the front audio cable, i was unable to stuff it under the motherboard because the cable consists of an AC plug, HD Audio plug, and Azalia plug. The HD and AC plugs don't fit under the motherboard. Hopefully some sleeving will remedy this nuisance.
Can't turn the drives around due to WD serial locks installed. Also going to extend the fan wire in the upper left, it bothers me.
For a pre-built that loop and wiring is pretty clean.![]()
I've updated my thread finally!!![]()
