centvalny said:As the title said...Also, your system spec.
I still have problem w/ xms 3500. After back and forth I decided to use Gskill permanently. B/way what is your neo2 chipset date? Mine is 0420 korea and do you know whre I can buy 939 cpu kit for Mach.jinu117 said:Check my sig. That is prime 95 stable at close to 1.9v on v-core.
Benches well up to 3.15ghz but... but... can't get memory to cooperate unfortunately (have to kick it down to 166mhz as I am hitting quite decent FSB and to maximize memory than i am talking 330fsb+) so stuck benching at 3.05ghz. Typically run at 2.95ghz @ 1.75v.
Now my mach II is R404 with cap tubing mod so consider it GT.
Your FX-55 probably should hit 3.4ghz benchable.
centvalny said:I still have problem w/ xms 3500. After back and forth I decided to use Gskill permanently. B/way what is your neo2 chipset date? Mine is 0420 korea and do you know whre I can buy 939 cpu kit for Mach.
Thanks jinu..B/way how's your enermax 660? I have the same one and it save me a lot of problems w/ oc. The only complain is looong cords.jinu117 said:I need to get back to home before chipset #, Have screenie somewhere.
http://www.hardwaregods.net/ has the kits at lowest prices I've seen on net.
centvalny said:Thanks jinu..B/way how's your enermax 660? I have the same one and it save me a lot of problems w/ oc. The only complain is looong cords.
Good to know that your mach back to work2Fresh said:siggg
My second neo2 won't work with enermax660. All components on exept cpu and chipset fans. No post. How bout yours?jinu117 said:No kidding, this PSU is the gift on us who is draining too much power with phase changeI am holding my judgement for now but I personally found it better than OCZ 520W by far so far. Cord is an issue definitely, I've put plastic wrapper for it for now (sleeving is an option but I prefer not to mess with $200+ PSU and sleeving is PITA. I have all the tools necessary but won't bother anymore
fx55jinu117 said:What CPU are you using on Vapo with neo2?
Just started, LS evaporator tem. is lower than 3700 oc'd at 2.95GJames Earl Ray said:What result are you getting?![]()
Gskill LEJames Earl Ray said:Damn son!That is awesome. What ram you got?
centvalny said:Gskill LE![]()
centvalny said:Orange co. its about 30 min from the city. James you gotta mount that vapo ls on your rig. This combo is deadly![]()
joecuddles said:Pfft, kids. Give 'em coal and blow it all on a Chilly1 dual cascade.![]()
sorry to hear bout your xtpe. That bba card must be an early batch of gpu and overclock like thoroughbred horse on steroidJames Earl Ray said:OC huh! I was in Newburgh a few weeks ago for my brothers wedding. I was born in the Bronx and moved to FLA about ten years ago.
As for the Vapo, I am tryin to take of Christmas for the kiddies first. Then I got it all planned out. But now it looks like I might need a new X800xt. RIP![]()
joecuddles said:My mem? 2.85v. It sucks >=|
centvalny said:Yep, along that R. 32 leading to NYS truway.
B/way sorry to hear bout your xtpe. That bba card must be an early batch of gpu and overclock like thoroughbred horse on steroid![]()
2.7VJames Earl Ray said:C'mon scrooge. Ok what Vdmm are you running that mem at?
James Earl Ray said:Hopefully this next gig will be better. As for the card, I think I can get it back. I kinda boogered a mod, so it might be reversible. I just have trouble in 03. All other benches I hit 675 no probs. Who knows I might have corrupted the OS. (Prays)![]()
James Earl Ray said:Nice clocks, but WOW what a hit in bandwidth.![]()
Yep, bw is important and we can see the differenceJames Earl Ray said:Nice clocks, but WOW what a hit in bandwidth.![]()
Where do you have the rad?
