SomeGuy133
- Apr 12, 2015
I see you run it at 1080P. It may not throttle at that point. 1080P is not a good test for the 980TI. It won't max out your card. At 4K it will throttle by 200-300 MHz.
If you have a no name PSU then I'm almost positive it's the PSU. Don't trust any no name PSU to output its advertised wattage. Your 700 watt is probably gutless and it may be AC wattage rather than DC. Also, if it's not 80 plus, it's efficiency is probably 60-70%. 70% of 700 AC is 490 DC watts.
The EVGA 850 G2 is 850 DC rated. That means it can draw up to 950 watts of AC power. Huge difference. Your PSU is probably not defective, it's just a gutless wonder and can't handle the 980 TI. Don't skimp on your power supply if you're buying a $700 video card!
99% certain that its industry standard that the wattage rating is output not input. At notebook review we discussed this thoroughly at one point figuring this out.
So when you buy a 700 watt PSU at 60% it'll put out 700 watts but will draw 1166 watts. An 80% will draw 875 watt
Again if i am pulling 80 TDP in furmark and no issue how is 50 TDP or less crashing in game. That makes no sense. Also the test is running at 100% load and 30 FPS. any higher res won't make a difference.
4K msaa 8x 1550 mhz +0mv
https://www.dropbox.com/s/4ederdsabtkbblx/furmark 4k msaa8x 1550 +0mv.png?dl=0
375 second with minor throttle. forgot what original is but its like 20 mhz less.
I get this voltage drop thing but I don't believe its a max output issue. The numbers don't add up for that but the up down and changing voltages would make sense if that is the issue.
