fluke420
- Jul 9, 2003
Not as many hds as some but what the hell
From my main rig, 4x20G in RAID 0 (living on the edge)
Kaleim said:
it should but it dosent.. theres something wierd with this board, that and room temps are always skyhigh its 3am here now and its 86°f makeing the cpu die read 116°, the oc im running now is multi only. This is a rev a board, the ram will do 400 but the cpu wont much over 380 and it craps out as this cpu is a first gen barton as well, 333 fsb with 512 cache... the box the borad came in say it supports 333fsb procs and 400 mhz ram... so yeah.. it craps out... so basicly i run 12.5x166 (2075~) most of the time and only run the 11x190 while at a lan (as where we lan has A/C ) other wise i basicly water cool for stability reasons...KORI said:that 2500+ sould be getting a higher OC on water?
TehRoflcopter said:Thore.
I suggest mounting that pump. Not only would it make your case look cleaner, but I do believe that it would be a little easier on the magnetic impeller on the inside =).
what kind of sata controller is that?EnderW said:old machine
IAmSpoli said:Other than for serving usage...wtf are u guys thinking using 10 hd's
That's fricking hilarious. I'm starting at these pics of computers with 6 hd's, 4 full of p0rn, movies, games, apps...
Leechers!!!!!
LSI MegaRAID SATA 150-4Dachink said:what kind of sata controller is that?
0mega said:and im sure thats 2.4TB of legally owned data
dchrsf said:Jesus!!! Why the 2 PSUs, and how are temps around on that thing!! I hope you got front fans!!
Which case btw?
RHollister said:completly offtopic and maybe wrong, but without knowing what motherboard that is I would say that you are not running dual channel. I think you need to move that second memory stick into the light blue slot.
nice HD setup by the way.
God_Of_Death said:2 psu's because i have killed my fair share of psu's due to overloading them. that case is a Lain Li PC-76. the temps are normal. hd's don't get hot, not even warm to the touch. the case has 4 80mm fans just for the hd's.
You sir are not using your computer to its potentialmalicious said:forgive my HDD newbness but what is file leeching
also .. i have like a 40gig drive and it's enough .. why do people need like a 1000gigs?
thanks
cyberphox said:http://www.genemills.net/pics/newserver4.jpg[/IMG]
kuyaglen said:From the [H] Terabyte Club thread:
http://www.hardforum.com/showthread.php?t=943660
Box for file leeching:
6x 250gigs (4 in a jbod array)
1x 200gigs
1x 160gigs
generic IDE controller card
Gaming rig (with a 7800GTX!):
1x 300gig
4x 300gig raid 0 1.08TB for pr0n (and its still not enough)
Promis SX4000Lite w/256MB pc133 ram
That is the before picture...
After picture to come when I get a Seasonic S12 600W psu to power all the drives in my fileserver (my current 500W is not enough).
alphakry said:i count either 15 or 16... not bad!!
i'de like to see the controller card setup thou...
