Post your Aquamark3 scores with your 6800GT OC'd
WeldZilla
Come let's have a look. I see a lot of OC numbers but I don't see what that is bringing you in the way of speed. So post your aquamark scores so everyone can see where there card stacks up on all this. I'll start it off. with a pick and a link post both if you can but definitely the link!! I want to look up the skirt of every 6800GT in here!! Hey I'll post both my card at stock
And here it is OC'd to 420/1100
http://arc.aquamark3.com/arc/arc_view.php?run=1019736164
It is one of the new PNY 6800GT Cards. CompUSA in Portland Oregon has lots of them. It is a good thing Cuz I returned 2 duds in 3 days to get this 3rd one that works great!! here are my system specs also:
Epox 4PDA2+Ver.2, 2.4C @ 3200mhz, 1gig @2x512megs OCZ PC3700 mem, 2x120gig maxtorhdd's in raid0 array, PNY 6800GT Vid Card. Pioneer DVD-Writer, Liteon, DVD-Rom,Antec 550watt True Power psu, Eheim pump,Swiftech 5002P
Water Block, GM heater core rad, pvc homemade water tank, 10 fans
So Post them up and let's have a look!!
Weldzilla
Godmachine
Well if i knew how to post pics i would show you mine of my BFG 6800nu with 62,345 Aquamarks :D :eek:
WeldZilla
Go to your ARC overview and set your details to public. Then click on view, when that page opens you will see the address there for you to share the link with us by copying and pasting it into your reply to us here in this thread. I use Quick screen capture for my pics. after you download it you get 30 free captures. then it is like 19.95. I use Photobucket as my host.
WZ
heyheyhey
I got 35,000 when I ran it last night... guess I never realized how much my processor was holding me back. :(
M1dknight
You must have something set wrong I get ito the 52k range with the machine in my sig.
TheRapture
AquaMark Score: 62799
(CPU: 9887, GFX: 9201) FPS: 62.80 TPS: 18904 K
CPU: AMD Athlon(tm) 64 Processor 3000+ CR: 2499 MHz
SRAM: 1024 MB OS: Microsoft Windows XP
GFX: NVIDIA GeForce 6800 GT CM: 11 / 0 MHz VRAM: 245 MB DRIVER: 6.14.10.6600
RES: 1024x768 x 32bit AA: Off AF: 4x DETAILS: Very High
INFO: therapture, 2004-08-29, "Benchmark 2004-08-29 09-39-54"
jawsh77
around 52,000 specs in sig, everything default, that seem about right to you guys?
centvalny
arc.aquamark3.com/arc/arc_view.php?run=1690249254 With amd3700@2711mhz/6800ultra 459core-1188mem.+dangerdenNV68 watercooled BlackIce xtremeII radiator w/ 2x delta ffb1212ehe fans. A few minutes after that my AntecTrue 550 smokin' and died.
4x wd120gb/raid0 w/3ware7500-4
Swiftech pump and cpu block and a lot of 80mm fans.
2X 512 corsair xms3500PT.
WeldZilla
centvalny get out of here with that ULTRA!!! That thing is brutal. Have you got a permit to carry that? Killer card you got there. Does it say " Keep out of reach of Children" on the box??
WZ
centvalny
WZ, I cant believe my luck w/ this card. First, on thr GPU core there is no NV40 mark and date of manufactured is 04 week of23(Late May) so, it must be a first production batch after sample. Secondly, I am at my 4th. psu now, Antec 480 just for this sucker and 550 for everything else. First, Antec 550 and 430 then thermaltake 550 all went up in smoke and died.
Novablade
GFX = 10,170
CPU = 10,678
_____________
68,895
BFG 6800GT OC o/c'd @ 400/1100
All else stock (see sig) :D
isp
thread revival :eek:
I posted my thoughts in your thread Cyphill, check it out...
and btw: I get about 62k stock...still looking to pickup an nv5 silencer before I start overclocking...
CypHill
Thanks for the reply - I replied as well...
Well I'm happy that everyone else is enjoying high scores. I can't wait until I figure out my problem.
I helped build a friend's rig with a 939 3200+ @ 2.4Ghz and a 6800GT PCI-e.. he's running up on 72K in Aquamark.
centvalny
mentok1982
Total 66,903 CPU 10,120 GPU 9,993
AquaMark Score: 66903 (CPU: 10120, GFX: 9993) FPS: 66.90 TPS: 20138 K
CPU: Pentium(R) 4 processor, HT:On CR: 3124 MHz SRAM: 1023 MB OS: Microsoft Windows XP
GFX: NVIDIA GeForce 6800 GT CM: 5 / 5 MHz VRAM: 251 MB DRIVER: 6.14.10.7644
