Post your AMD unlock pass/fail here! v. 2.0 + How to unlock (Please limit discussion)
sandaflo
Processor: x2 555 BE
Unlock pass or fail: pass - unlock to x4 B55
Motherboard: Biostar TA870+
CPU Cooler: AC Freezer Pro 64
Voltage:1.440
---ADDITIONAL INFORMATION---
CPU Stepping: CACDCAC1046FPM
BIOS Version: 080015
Stability test application(s) used: Prime95 64bit
Amount of time passed in stability app: 3.5 hrs
Any other pertinent info: used onboard unlocking function from Biostar; voltage seems a little high considering I have left the clocks stock at 3.2ghz. Will try to tweak manually with lower voltage.
Snittako
Processor: x3 720 BE
Unlock pass or fail: pass - unlock to x4 920
Motherboard: Biostar A880g+
CPU Cooler: Kingwin xt-1264
Voltage:1.38
---MANDATORY INFORMATION---
Processor: Phenom II X2 555 BE
Unlock pass or fail: FAIL
Motherboard: ASRock 870 Extreme3
CPU Cooler: Arctic Cooling Freezer 64 Pro
Voltage: 1.4625V
CPU Stepping:
BIOS Version: American Megatrends P1.60
Amount of time passed in stability app: 6 Hours
Any other pertinent info: Overclocked with 2 cores to 3.8 GHz. Unlocking results in no POST
Silix
Processor: Athlon II X3 435
Unlock pass or fail: PASS to Phenom II X4 B35 (6MB L3)
Motherboard: MSI 880GM-E41
CPU Cooler: Stock
Voltage: 1.34V
CPU Stepping: C3
BIOS Version: American Megatrends V11.8
Stability test application(s) used: Prime95, OCCT
Amount of time passed in stability app: 8 Hours Prime95, 2 Hours OCCT
Processor: Athlon II X3 425
Unlock pass or fail: PASS to Phenom II X4 B25 (No L3)
Motherboard: MSI 870-G45
CPU Cooler: Coolermaster Hyper TX3
Voltage: Stock
CPU Stepping: C2
Amount of time passed in stability app: 10 Hours
dmark
Processor: Athlon II x2 5000, AD5000ODJ22GI
Unlock pass or fail: Fail
Motherboard:Gigabyte GA-MA785GM-US2H
CPU Cooler: Stock, then OCZ Vendetta
Voltage: 1.2V>>1.35V
CPU Stepping: CACZC
BIOS Version: F10
Stability test application(s) used: Prime 95 small patterns then large
Amount of time passed in stability app: 24hrs each
Any other pertinent info: Stable 2 cores 11x275=3025mhz, week 0950
dmark
Unlock pass or fail: Pass
Voltage: 1.2V
CPU Stepping: CACVC
BIOS Version: F10
Any other pertinent info: Stable 4 cores 10x266=2660mhz, week 0946
dmark
Processor: Athlon II x2 5000, AD5000OGJ22GI
Voltage: 1.2V
CPU Stepping: CACUC
BIOS Version: F10
Any other pertinent info: Stable 4 cores 11x266=2926mhz, week 1011
dmark
Voltage: 1.2V
CPU Stepping: CACUC
BIOS Version: F10
Any other pertinent info: Stable 4 cores 11x275=3025mhz, week 1011
nxcess
Processor: AMD x2 560BE
Motherboard: MSI 785GTM-E45
CPU Cooler: Thermalright SI-128
Voltage: 1.440
CPU Stepping: unknown
BIOS Version: V8.8
Stability test application(s) used: Linx
Amount of time passed in stability app: 20 passes
Any other pertinent info: 16x250 @ 1.440v | Best $100 spent
n3ckcutta
Looking through all this and now I want to go home and start my PII X2 555BE build. Will post up results when I have it all stable and running correctly.
fuelvolts
Processor: Athlon II x3 435
Motherboard: Foxconn A7DA-S 3.0
CPU Cooler: Cooler Master Hyper TX3
Voltage: 1.440
CPU Stepping: unknown (purchased May 2010)
BIOS Version: P07 (newest)
Stability test application(s) used: N/A
Amount of time passed in stability app: N/A
Any other pertinent info: Wouldn't even POST with core unlocked. Damn.
:mad::mad::mad::mad::mad::mad::mad:
UPDATE:
4/14/2011
IT WORKS!!!!!!
So far stable at idle; running stress testing now.
Zarathustra[H]
Extremely [H]
I wish everyone would post the production week of their CPU's.
I have this sneaky suspicion that the production week (and the stepping - of course) are the two most important predictors of success in unlocking.
The production week of my CPU was 1041, or in other words week 41 of 2010, or some time in early October 2010
If you bought your CPU a long time ago, or if it sat for a long time on the retailers shelves, then even if its the same model number and stepping, the success rate will likely be lower, because of continuous improvement activity at the foundry causing yields to become better over time.
mumyoryu
Processor: Phenom II 555BE
Unlock pass or fail: pass - quad
Motherboard: MA790x-UD4P, TA785GE
CPU Cooler: TRUE
Voltage: stock 1.4v, can do lower
CPU Stepping: CACAC AC 1004CPMW
BIOS Version: F9 (on the UD4p), dont really remember on the TA785GE. I think it was 0518
Stability test application(s) used: LinX, Prime
Amount of time passed in stability app: 20 runs full mem in LinX, 12+ hrs Prime small FFTs and Blend
Any other pertinent info: Bought March 2010, had a 550 that failed to unlock a few months before so was ecstatic when the 555 unlocked :D
86 5.0L
Processor: Sempron 140
Motherboard: MSI 785GM-P45
CPU Cooler: Coolermaster Hyper 212+
Voltage: Stock (1.38v I believe)
CPU Stepping:
BIOS Version:
Stability test application(s) used: OCCT and F@H
Amount of time passed in stability app: 12 hours
mastrdrver
I've noticed (of recent) that according to the Newegg reviews the best chance for a successful dual Phenom II X2 to unlock to a quad is to get the top dual core which is the 565 currently.
SirTanon
Unlock pass or fail: Pass - B55 Quad
Motherboard: MSI 880GM-E43
CPU Cooler: Rosewill RCX-Z1
Voltage: Stock Voltage
CPU Stepping: (Will have to check when I get home)
BIOS Version:
Stability test application(s) used: 3dMark03, MSI Afterburner
Amount of time passed in stability app: 1+ hour
Any other pertinent info: Bought April 2011. Runs perfectly stable on 3.2Ghz. Have not OC'd yet.
Flyinfinni
Motherboard: GIGABYTE GA-MA785GM-US2H
CPU Cooler: Stock
Voltage: Stock
Bought and built in early 2010
CPU Cooler: Stock
Voltage: Stock
Don't have it anymore- built for my in-laws. Was built back in fall of '09 though.
fuelvolts
I edited my post (#172), running unlocked so far at stock
Athlon II X3 435 unlocked to Phenom II B35 (no L3)
JMccovery
Processor: Phenom II x2 555
Unlock pass or fail: PASS!!! :D Quad currently at 3.8GHz
CPU Cooler: Scythe Mugen (Fanless, but bombarded by 140mm and 120mm Antec Tri-cools on high in Antec 300)
Voltage: 1.44v (Default of 1.26v with overvolt of 0.175v)
CPU Stepping: Forgot exactly what it was, crappy cell phone pic doesn't help, either. I think it is similar to the one in Zarathustra's pic
Stability test application(s) used: wPrime & IBT
Amount of time passed in stability app: wPrime 5 runs of 1024M, IBT 2 5-run tests
Any other pertinent info: Would take a while to post with all four cores enabled, have to turn off then on again or reset a few times to get post. (Also, apparently, A7DA-S doesn't like unlocking the cores, since there is almost no way to monitor temps, even the Temp1/2/3 barely changes when stressing/gaming.) <-- Forget this. All in an Antec 300 with 2 low-speed Yates in front, 1 Scythe Slipstream-L on the sidepanel.
Decided to edit this post rather than make a new one.
According to Speedfan, Temp 3 is my CPU temp. With the 120 and 140mm Tri-Cools set on high, I never go over 58°C. Stable Quad @ 3.8GHz,
n1helix
Processor: AMD Phenom II 720
Motherboard: GIGABYTE GA-890GPA-UD3H
CPU Cooler: Mugen 2
Voltage: Stock
CPU Stepping:
BIOS Version:
Any other pertinent info: BSOD when stressed
CorNut
Unlock pass or fail: fail
Motherboard: Asus M4A79XTD EVO
CPU Cooler: Stock
Voltage: Auto
CPU Stepping:
BIOS Version:
I failed at this a while back and that motherboard currently has a 1090t in it. I actually have another motherboard where this Sempron will find its own home (BIOSTAR A780L3L) and I will try to raise voltage a bit, that is something I didn't even think about doing. I'll also be using the 1090t's stock cooler with some tuniq tx-4 since the 1090t has a corsair cooler. Even if I fail again with the biostar board I'll at-least try to get a good OC on the single core
AthlonXP
Processor: Phenom II X2 560
Motherboard: Gigabyte GA-880GA-UD3H
CPU Cooler: Stock
Voltage: Auto
CPU Stepping: n/a
BIOS Version: F7
Amount of time passed in stability app: 4 hours
First AMD Rig in 5 years for me.
Thor
Processor:AMD phenom 2 x2 560
Unlock pass or fail: pass (shows as AMD phenom 2 x4 b60)
Motherboard:m4n98td evo rev2
CPU Cooler:stock
Voltage:1.312-1.328 (cpu-z)
CPU Stepping:family f model 4 stepping 3 revision rb-c3
BIOS Version:1003
Stability test application(s) used: occt, many many games
Amount of time passed in stability app: occt 4hrs, (i ran it untill my case temps leveled off)
Any other pertinent info: stable on all 4 up to 3.8ghz on the stock cooler, at default voltage but it gets really hot, 3.5 daily use untill i can get better cooling.
second rig is exactly the same, every bit of it passed the same, only i have not tried OC'ing at all (same mother board, same ram, same bios, save vid cards, as sig rig)
so put me downs for 2 unlocked P2x2 560's >p2x4 b60's
Team Obi Juan
Your Local Postmaster
Motherboard: Biostar A880G+
CPU Cooler: Zalman CNPS 8700 NT
Voltage: Auto
CPU Stepping: n/a
BIOS Version: Unknown
Any other pertinent info: Tried using the "Hit F3 now to run Bio-unlocKING" and then manually in BIOS enabling ACC. Won't even POST either way. Brand new parts all around.
Syngensmyth
Unlock pass or fail: Pass 4 Cores
Motherboard: ASRock 870 EXTREME3
CPU Cooler: Noctua NH-D14
Voltage: 1.457
CPU Stepping: C3 Revision HDZ555WFGMBOX
BIOS Version:
Stability test application(s) used: Prime95, and others
Amount of time passed in stability 9+ hours
CPU MHZ 3902
RAM Gskill F3-12800CL9D-4GBRL, speed 743/1486, timings 8-8-7-22
NB 2676, NBV 1.3, HT 2007, Multiple 17.5
Nside
Too bad I didn't see this thread before giving the PC to the owner...
I unlocked a Phenom II 555 (x2) last week. It is now running as a 4 core B55. I used ASRock 870 EXTREME3 MoBo with the onboard unlock utility. Everything was stable, no overclocking.
It makes me kind-of sick because I had him buy the parts, and the processor was on sale. I paid $150 for my 965 (x4), he paid $80 for the 555... I went ahead and gave him my old HSF from my 965, though temps seemed normal even with that puny 555 HSF (37-idle,64-load)... I'm betting that thing would overclock like a beast...
bart1975
I Steal Games
Processor: Athlon II X3 450
Unlock pass or fail: fail reboots when trying to boot into windows.
Motherboard: Asus M4A88TI Deluxe
CPU Cooler: Vortex Plus
Voltage: Auto
CPU Stepping:3
Revision BL-C3
JMccovery
I wanted to update on my 555: Since it is a little warm in my house right now, I've been looking at how high I can clock my unlocked 555 without going over 1.35v. I think I have one of those 'retail availability' locked 555's, basically a chip that could be sold as a 95w 955/965, but since 555's sell better (cheaper) AMD locked the cores to make it a X2.
The chip runs up 3.6GHz unlocked to quad at default voltage (1.26v, I run an extra .05v on it for CnQ stability), and the CPU-NB runs up to 2.6GHz at 'stock' voltage (my A7DA-S keeps the CPU-NB voltage at 1.31-1.34v) I might try to see how far I can take the NB to before I need to increase the voltage.
Processor: AMD Phenom II x2 550 Black Edition
Unlock pass or fail: PASS (all 4 cores)
CPU Cooler: Zalman CNPS10X Quiet
Voltage: 1.34V
CPU Stepping: 2
BIOS Version: 2001
Stability test application(s) used: Prime95, Super_PI, AMD OverDrive
Amount of time passed in stability app: one run of ~30min then let it run for a couple of more hours without a hitch, 2nd run of ~2hrs completed without errors or warnings
Any other pertinent info: didn't disable Cool'N'Quiet, just enabled the ACC to Auto and set it to Unleashed. 42ºC in full load, ~36ºC in idle
And to think I had this baby for over a year and a half now and had no idea how "special" it was...
TASL
CPU Cooler: Mugen 2
Voltage: Stock
CPU Stepping:
BIOS Version:
Processor: Phenom II x3 720
Unlock pass or fail: PASS!!! Quad currently at 3.2GHz
Motherboard: Gigabyte GA-MA790XT-UD4{
CPU Cooler: Zalman CNPS5X
Voltage: Default
CPU Stepping: Not sure on the Stepping. But thought I'd try it before buying a x4 or x6, saved a few bucks!
BIOS Version: F8g
Any other pertinent info: Sometimes the comp will go to sleep and never wake up.
Scooter30
----Mandatory Information----
Processor: AMD Phenom II X3 720 Black Edition
Motherboard: Gigabyte MA770T-UD3P
CPU Cooler: Sunbeam Core Contact
Voltage: 1.424
CPU Stepping: C2
BIOS Version: F2
edit:Update
After updating BIOS to latest version,I now have a successful unlock.
Thanks to alf717 for the suggestion.
Dylan80
Thanks to all those who posted! :D Check out my somewhat lucky results, and (please) chime in if you know your stuff and can help me get the most of it :) :
Processor: AMD Athlon X3 450 - 3.2 Ghz(stock) -- cost=$75 new
Unlock pass or fail: PASSED
Motherboard: Asus M4N68T-M-V2 -- cost=$50 new
CPU Cooler: Stock AMD Athlon X3 fan & heatsink
Voltage: 1.428V vcore voltage(set with "AUTO" Asus BIOS settings, NOT manual) but the 4th core also ran fine with stock voltage.
CPU Stepping: C3
BIOS Version: 0702
Stability test application(s) used: Prime95 (2-5 hours, will test more though)
Amount of time passed in stability app: 2-5 hrs
Any other pertinent info:​
Bought the most potentially unlockable stuff I could find with lowly amount of money available. To add, only spent only $15 on new 1x 2GB of Patriot DDR3 PC10600. Total cost for cpu/mobo/ram upgrade = $145 shipped.
This version of BIOS does not seem to have ACC anywhere, maybe I need to upgrade my BIOS to see this feature???? Anyone know? PM me. So... I just used all the auto settings on this motherboard, which came with this version of BIOS (ver. 0702, dated Jan/2011, and didn't upgrade yet)
No L3 cache :( , but I easily unlocked the 4th core making my system:
Athlon X3 450 3.2Ghz
((((overclocked/unlocked to: )))
AMD Phenom II X4 B50 @ 3.306Ghz
Also, all of this was done with the feature "Cool 'n' Quiet" activated..... I tried turning it off and received the same results either way. With the unlock only, I get 49C in BIOS. With both unlock and AUTO overclock above it jumped to 51C degrees. I will update this page if OR when I upgrade my BIOS, and get a good cooler since I am only running stock CPU heatsink from AMD.
If your :cool: L33t overclocking skills :cool: can help me unlock the L3 cache with something my newb ass missed... please please please PM me, please. :cool:
For the [H]!
aphasia
Processor: AMD Phenom II X2 555 Black Edition
Unlock pass or fail: PASS (4 cores unlocked)
Motherboard: Asus Crosshair V
CPU Cooler: Custom water cooling (details in notes below)
Voltage: 1.45625v (actual vcore lower in windows, board under volts. could probably set is lower while @ stock 3200MHz)
CPU Stepping: 3 (revision RB-C3)
BIOS Version: 0705
Amount of time passed in stability app: 2hrs initially at stock 3200MHz
Cooling: WC loop: Swiftech GTX CPU block, EK chipset block (NB & VRMs), 3x dual 120 radiators, D5/655 pump.
Still OC'ing system
Current Clock: 3913MHz (200.7 x 19.5) all 4 cores stable.
Vcore: 1.475 (Bios) / 1.476 (CPU-Z loaded) LLC enabled
system kinda overkill for this chip. bought it for shits-&-giggles to play with CHV till Bulldozer arrives.... eventually.
thought chip was a dud when i first tried to unlock a few months ago till i realised you need to up the volts to support the extra cores. don't laugh, my first AMD system since my Operton 170 / Socket 939 board.
KazeoHin
Motherboard: Gigabyte GA-MA785GM-US2H
Bios: F12a
Processor: AMD Phenom II X4 960T (Unlocked Multiplier)
Unlock Pass Or Fail: PASSED
CPU Cooler: Thermalright HR-01 Plus
Unlocked To: 6 Cores (AMD Phenom II X6 1600T)
Voltage: 1.216
CPU-Z (x64) Validation
http://valid.canardpc.com/show_oc.php?id=1957201
http://valid.canardpc.com/show_oc.php?id=1957197
Before Unlock
After Unlock
ACC To Auto
HOW did you get your hands on a 960t? I thought these were never mass-manufactured!
=HPSF=Roadrunner
Are we still doing this? I just got a PhII X2 560 BE. I just assumed it might be in the same 'unlockable' category as my 550 BE, but I didn't see any results for the 560 BE. God I hope; I just bought this for my son's rig for his birthday. I think I am more excited than he is, at the prospect of getting to try another unlock, and see what it will run at.
My 550 BE easily has to be my favorite hardware purchase ever, for the unlocking potential, and the overclocking. it's just fun to buy.
