AMD Sempron 140. Unlocks second core. Have run as high as 4.1 under chilled water.
But can easily do 3.8 under my Zalman CNPS10X Performa.
couldnt unlock my 445 Rana was well worth a shot tho Rig in Sig
Unlocked my
X3 450 @ 3.2
to an x4 b50
Pass!
fourth core unlocked.
If you have the same setup as someone else, would it be safe just to enter their stable settings strait in to your bios? Or should you work up to those numbers?
---MANDATORY INFORMATION---
Processor: Athlon II X2 210e
Unlock pass or fail: FAIL
Motherboard: MSI 785GM-P45
CPU Cooler: CoolerMaster GeminII
Voltage: up to 1.396V
---ADDITIONAL INFORMATION---
CPU Stepping: C2
BIOS Version: 11.8
Bios unlocks it and sees all 4 cores, but it auto-restarts while at the Win7 loading screen. Tried disabling cores 3 and 4 individually as well as ACC -12% on the 3rd and 4th core with no luck. Tried voltage up to 1.396V (and 1.18V NB) with same issue.
3.12GHz (260x12) isn't stable on stock volts using Intel BurnTest, but 3.0GHz (250x12) seems perfectly fine so far. 29*C load temp so far (22*C room temp) using BurnTest. This HSF is AWESOME.
Was hoping for a stable unlock, but its not a huge deal as it is in an HTPC and will not really be used for much besides playing Blu-Rays and other media. It'll get the occasional game thrown at it, but I don't play anything recent enough to stress it anyways.
EDIT: Corrected BIOS version
Zarathustra[H];1036638474 said:---MANDATORY INFORMATION---
Processor: AMD Phenom II 555BE
Unlock pass or fail: Pass to 4X
Motherboard: MSI 870S-G54 (AMD 870)
CPU Cooler: Stock Cooler from a Phenom II X4 965BE
Voltage: Unlocked at Stock plus .05V
CPU Stepping: CACDC AC
BIOS Version: Not Sure.
Stability test application(s) used: Prime 95
Amount of time passed in stability app: Several hours
Any other pertinent info:
Now running at 4.02Ghz (206x19.5) at 1.450V Max Prime95 load temperature is 49C.
PhenomII by mattlach, on Flickr
I'm sure I could get more out of it but 55c is my stopping point. Infact I may drop it back down to 4050 @ 1.48
