Does anyone else find that the top 120mm exhaust fan causes an annoying vibration humming sound in their P182?
Is it an Antec Tricool fan?
http://www.hardforum.com/showpost.php?p=1032094146&postcount=800
did some work since last time i posted in here a few weeks ago...
*SNIP*
i get it in my p180b i dono if its just tri cools or all fans but it suks!!
I took the top fan out of my case. All it does is make noise. My temps are lower with it removed.
@Fritzz
It's a relief to see the Quattro 850 fit in the P182 without permanently losing the lower fan, as I've just bought those bunnies for next months build and wasn't sure if it would work. :-D
Anything in particular I should note about the fit and the cable lengths?
I would really like to see some pics of some one who has gotten a mini P180. I'm curious to see how everything fits.
Im not rich.
Im not rich.
Just wanted to mention that you might want toc heck on your RAM. I'm not sure, but youmight have to put your ram in slots 0/2 or 1/3 to take advantage of the dual-channel aspects of it.
BTW, the stock intel fan is fine if you're not OC'ng.
Yeah? What should I replace them with?Get rid of the TriCools -- they're horrible fans.
They're not 'horrible' by any means, just not as quiet as the best.
Scythe S-Flex's? I bought a bunch of SlipStream fans (Scythe's new fans) 1600 RPM and they're all very quiet and seem to move a lot of air...
I don't think my Noctua fan pushes enough air for my heatsink.
I was thinking of buying a Scythe to replace it, but if the TriCools are so bad, I could buy three Scythes and replace all the main fans.
Side on:
CPU = 43C
GPU = 56C
Side off:
CPU = 36C
GPU = 50C
CoreTemp and RivaTuner for the temps.
S12 rated at 48 CFM, P12 rated at 54 CFM.Which Noctua is it? If it's the P12 it's fine -- if it's the S12, its not fine -- move it to a case fan and get a better fan for HSF.
Not so much the smaller cfm increase, but the P12 has a higher static pressure output than the S12. Meaning it's better at pushing air in areas of high resistance, like a tight packed finned heatsink. The Noctua site doesnt have static pressure stats on the S12, only on the P12, so theres no good comparison there, but I've seen reviews that did low tech tests that showed the P12 puts out more static pressure.S12 rated at 48 CFM, P12 rated at 54 CFM.
The extra 6 CFM of air makes that big of a difference?
I'm going to shoot for at least 80+ CFM for a replacement fan. My Scythes say "88 CFM" and they don't make any noise, may as well put one of them on there.
Also I have an old case fan (Apevia brand) added into the P182, in the front fan slot.
[edit]
I just ordered three SlipStreams:
Two 1600 RPM and one 1900 RPM.
I hear rumors that some of them leak oil, but the ones I own thus far haven't leaked.
I'll post back in a week or two with updated temps.
A picture of the lights with the side panel on, it keeps the vibrance of the led's down so that they're aren't annoyin.
All in all pretty happy with the build. Let me know what yall think, thanks.
