POST and CONNECT commands in weblog
the-one1
66.111.34.20 - - [10/Sep/2004:16:02:47 -0500] "CONNECT 66.111.34.29:6667 HTTP/1.0" 404
69.50.180.66 - - [10/Sep/2004:16:03:03 -0500] "CONNECT 69.50.180.75:6667 HTTP/1.0" 404
83.97.97.3 - - [21/Sep/2004:06:30:34 -0500] "POST http://209.136.21.35:6667/ HTTP/1.0" 404
207.46.98.86 - - [10/Sep/2004:12:21:07 -0500] "GET /robots.txt HTTP/1.0" 404
What is it? I tried google but nothing.
thnx
Xipher
the Connect ones look like its tyring to use your webserver as a proxy, the post might as well. The get robots.txt is one that I think has to deal with search engine stuff.
Xipher
no, as your server responded with a 404, document not found, I would get these as well, often happening when I would connect to irc from the same ip (I happen to use NAT and the irc network does check on connection to make sure your not connecting via proxy.)
