I was wondering if it was at all possible to create a batch file to enable and disable my second display (which is actually a tv)
The command would have to turn on the display, and also change its location relative to my primary display. I wouldn't even know where to start; Google doesn't yield any fruitful results.
Any input is much appreciated, thank you
This is on Vista, but that shouldn't make a difference.
