Well first things first.
The motherboard is a Gigabyte 990FXA UD3 rev 1.0
The Fans are Corsair SP120's
According to gigabyte the fan headers can support up to 4 amps. Corsair's website say they draw 1.8a each at full load. There is little room for error here, so figured i'd ask.
The reason, currently the fans are being run @ 7 volts (supplied voltage reducers). They are quiet, yet when gaming for long sessions the computer can heat up, and I'd like to run the fans at a higher voltage during these times. I figured I could just hook them up to the PWM on the motherboard and have the motherboard control the voltage when things heat up.
Its not dire the computer doesn't overheat or crash or anything, just would be nice to lower the temp a bit when its running at full load. I rather not burn out the fan header.
