once you heat them, they will rupture (if not explode) and be as useless as hollow copper tubing. heatpipes are specificly engineered for their specific interior volume and filled with a very specific amount of gas, when you bend them you will most likely change this volume and they will not work nearly as well, if it still works at all.
I don't think you understand how volume works in close spaces... He isn't trying to elongate the heatpipes, simply trying to change their orientation which should be fine as he is not going to change the volume by simply bending them, if he was adding more bends i might see a problem as he might be condensing it down, but by simply unbending the pipes i don't think it would have a harmful effect
ive done it before on a thermostat to an A/C unit, i wish i had a heatpipe layin around so i could get some pictures.... but if you hold a torch to the end opposite the solder, it has no time to heat up, at best the solder plug shoots off into the wall, at worst the pipe splits down the side making a good loud bang. and yes you dont need to do this to bend a little pipe like that, its not steel or iron.There is not enough liquid inside them so they could explode, the solder with which they are usually sealed will melt long before that and let the liquid evaporate
Once you bend them, you will pinch it at the bends, unless you know how to mandrel bend copper
springs might work but theres no way of getting them on the pipe because on most heatsinks the pipes are not removable.
