port forwarding is not working when OpenVPN client is active
mrjayviper
I'm trying to SSH into a UNIX box in my home network from work but the connection is timing out. I looked at my port forwarding settings everything seems to be ok.
Port forwarding works fine if I turn off the OpenVPN client.
Can you please help find a fix to my problem that doesn't involve turning off OpenVPN client? if it's fixable of course.
Thanks a lot!
some info:
1. I can access the DDWRT Web Admin website remotely.
2. OpenVPN client is active. I have used Policy-based Routing setting to be able to access my router Web admin remotely.
3. iptable commands (all commands were run using DDWRT Administration => Commands unless stated otherwise)
Code:
#iptables -t nat -vnL PREROUTING
Chain PREROUTING (policy ACCEPT 3771 packets, 268K bytes)
 pkts bytes target     prot opt in     out     source               destination
  469 29996 DNAT       tcp  --  *      *       0.0.0.0/0            ISP-provided-static-IP         tcp dpt:443 to:192.168.1.1:443
    2   112 DNAT       icmp --  *      *       0.0.0.0/0            ISP-provided-static-IP         to:192.168.1.1
    0     0 DNAT       udp  --  ppp0   *       0.0.0.0/0            ISP-provided-static-IP         udp dpt:56010 to:192.168.1.31:56010
    0     0 DNAT       tcp  --  ppp0   *       0.0.0.0/0            ISP-provided-static-IP         tcp dpt:56010 to:192.168.1.31:56010
    7   448 DNAT       tcp  --  *      *       0.0.0.0/0            ISP-provided-static-IP         tcp dpt:3283 to:192.168.1.11:3283
    0     0 DNAT       udp  --  *      *       0.0.0.0/0            ISP-provided-static-IP         udp dpt:3283 to:192.168.1.11:3283
   10   592 DNAT       tcp  --  *      *       0.0.0.0/0            ISP-provided-static-IP         tcp dpt:5900 to:192.168.1.11:5900
    0     0 DNAT       udp  --  *      *       0.0.0.0/0            ISP-provided-static-IP         udp dpt:5900 to:192.168.1.11:5900
    0     0 DNAT       tcp  --  *      *       0.0.0.0/0            ISP-provided-static-IP         tcp dpt:322 to:192.168.1.13:322
    0     0 DNAT       udp  --  *      *       0.0.0.0/0            ISP-provided-static-IP         udp dpt:322 to:192.168.1.13:322
    3   192 DNAT       tcp  --  *      *       0.0.0.0/0            ISP-provided-static-IP         tcp dpt:522 to:192.168.1.15:522
    2    56 DNAT       udp  --  *      *       0.0.0.0/0            ISP-provided-static-IP         udp dpt:522 to:192.168.1.15:522
 2320  145K TRIGGER    0    --  *      *       0.0.0.0/0            ISP-provided-static-IP         TRIGGER type:dnat match:0 relate:0
 #iptables -vnL FORWARD
 Chain FORWARD (policy ACCEPT 330 packets, 22973 bytes)
  311 15092 ACCEPT     0    --  *      *       0.0.0.0/0            0.0.0.0/0           state RELATED,ESTABLISHED
 6222  430K lan2wan    0    --  *      *       0.0.0.0/0            0.0.0.0/0
    0     0 ACCEPT     0    --  br0    br0     0.0.0.0/0            0.0.0.0/0
    0     0 ACCEPT     udp  --  *      *       0.0.0.0/0            192.168.1.31        udp dpt:56010
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            192.168.1.31        tcp dpt:56010
    7   448 ACCEPT     tcp  --  *      *       0.0.0.0/0            192.168.1.11        tcp dpt:3283
    0     0 ACCEPT     udp  --  *      *       0.0.0.0/0            192.168.1.11        udp dpt:3283
   10   600 ACCEPT     tcp  --  *      *       0.0.0.0/0            192.168.1.11        tcp dpt:5900
    0     0 ACCEPT     udp  --  *      *       0.0.0.0/0            192.168.1.11        udp dpt:5900
    0     0 ACCEPT     tcp  --  *      *       0.0.0.0/0            192.168.1.13        tcp dpt:322
    0     0 ACCEPT     udp  --  *      *       0.0.0.0/0            192.168.1.13        udp dpt:322
    3   192 ACCEPT     tcp  --  *      *       0.0.0.0/0            192.168.1.15        tcp dpt:522
    2    56 ACCEPT     udp  --  *      *       0.0.0.0/0            192.168.1.15        udp dpt:522
    0     0 TRIGGER    0    --  ppp0   br0     0.0.0.0/0            0.0.0.0/0           TRIGGER type:in match:0 relate:0
 6200  429K trigger_out  0    --  br0    *       0.0.0.0/0            0.0.0.0/0
 5870  406K ACCEPT     0    --  br0    *       0.0.0.0/0            0.0.0.0/0           state NEW
4. result of route -n
Code:
#route -n
 Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         10.20.21.18     0.0.0.0         UG    0      0        0 ppp0
10.20.21.18     0.0.0.0         255.255.255.255 UH    0      0        0 ppp0
10.208.111.17   0.0.0.0         255.255.255.255 UH    0      0        0 tun1
127.0.0.0       0.0.0.0         255.0.0.0       U     0      0        0 lo
169.254.0.0     0.0.0.0         255.255.0.0     U     0      0        0 br0
192.168.1.0     0.0.0.0         255.255.255.0   U     0      0        0 br0
5. result of ping commands
#ping -c 5 192.168.1.13
PING 192.168.1.13 (192.168.1.13): 56 data bytes
64 bytes from 192.168.1.13: seq=0 ttl=64 time=1.887 ms
64 bytes from 192.168.1.13: seq=1 ttl=64 time=0.615 ms
64 bytes from 192.168.1.13: seq=2 ttl=64 time=0.628 ms
64 bytes from 192.168.1.13: seq=3 ttl=64 time=0.580 ms
64 bytes from 192.168.1.13: seq=4 ttl=64 time=0.555 ms
--- 192.168.1.13 ping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 0.555/0.853/1.887 ms
#ping -c 5 192.168.1.15
PING 192.168.1.15 (192.168.1.15): 56 data bytes
64 bytes from 192.168.1.15: seq=0 ttl=64 time=0.758 ms
64 bytes from 192.168.1.15: seq=1 ttl=64 time=0.378 ms
64 bytes from 192.168.1.15: seq=2 ttl=64 time=0.359 ms
64 bytes from 192.168.1.15: seq=3 ttl=64 time=0.402 ms
64 bytes from 192.168.1.15: seq=4 ttl=64 time=0.440 ms
--- 192.168.1.15 ping statistics ---
round-trip min/avg/max = 0.359/0.467/0.758 ms
6. result of nmap command. This was run remotely (at work).
Code:
08:52:21 Tue Jul 21
root@mymacbook : ~
=> nmap -sT -sU -p 522 ISP-provided-static-IP
Starting Nmap 6.49BETA4 ( https://nmap.org ) at 2015-07-21 08:52 ACST
Nmap scan report for ISP-provided-static-IP (ISP-provided-static-IP)
Host is up (0.00034s latency).
rDNS record for ISP-provided-static-IP: ISP-provided-static-IP
PORT    STATE         SERVICE
522/tcp filtered      ulp
522/udp open|filtered ulp
Nmap done: 1 IP address (1 host up) scanned in 0.51 seconds
7. result of ssh command. This was run remotely (at work).
Code:
08:52:28 Tue Jul 21
root@mymacbook : ~
=> ssh -p 522 myuser@ISP-provided-static-IP
ssh: connect to host ISP-provided-static-IP port 522: Operation timed out
