Port 80 in use by system - help needed.
vitoc
I have a for me, very strange problem.
I installed Windows Server 2008, on my freshly new bought server.
During the installation process I also installed IIS.
When the installation was complete, I had some disscussions regarding running IIS, or Apache. The vote fell for Apache. So I unistalled IIS. Removed it from services, etc.
Installed Apache, and it complains about port80 is in use by microsoft HTTPAPI/2.0
I have googled, but cant cant seem to find any info what so ever.
I ran the command NETSTAT -p tcp -ano
That command shows the PID for open ports.
Port80 was used by PID4.
So, I opened taskmanager, added "show pid" and to my suprise, PID4 is "NT Kernel & System" Owner SYSTEM
Googled some more, came up with absolutely nothing.
Decided to do a "ugly work around"
I installed IIS again, and then ofcourse Apache says "Port 80 in use by IIS"
So, I changed the default port in IIS to 82...
And now we are back to "Port 80 in use by microsoft HTTPAPI/2.0"
So, that didnt work.
I have no idea what to do, I doubt there is a way for Apache to get higher priority then SYSTEM to the port.. So how do I fix it so that Port80 isnt in use by the system?
If I try to go to localhost I get this:
Not Found
HTTP Error 404. The requested resource is not found.
If I install IIS, I ofcourse get the IIS splashscreen.
Anyone, please give me some ideas.
Best Regards.
/Vitoc
Xipher
Make sure you stop the world wide web publishing service in the service manager. While IIS may not be installed the services it manages probably are.
vitoc
As a matter of fact, they are not installed, nor are they listed as a service.
Thanks for a quick answer tho!
mmtom
How did you remove it? You need to go into server manager, go to roles, and remove the IIS role.
vitoc
The problem is solved now, I have absolutely no idea how I solved. But it is now working with Apache.
I know this cant have anything at all to do with it, but it started working after I installed MySQL.
pcgeek86
The only other thing I can think of is that WinRM uses port 80 too. WinRM will share the port with IIS if IIS is present. I'm not sure if WinRM runs under the System process or not though. That's all I can think of.
D-OveRMinD
I know this is an old thread, but it came up in google when searching for this issue.
I had a VMware Virtual Center Server Service that would not start. I got the same errors as above with netstat saying PID 4 / System was using port 80.
It wound up being Windows Remote Management that was using the port, as I did not have IIS installed.
Worked perfectly, thanks guys!
In order to use third-party HTTP services such as Apache on port 80, and 443 on Windows 7, and Server 2008; you will need to disable the following services then reboot:
WebClient
Web Deployment Agent Service
Microsoft .NET Framework NGEN.
If you use the Windows Firewall; you will need to set your ports for access in the Windows Firewall with Advanced Security snap-in for each designated port such as 80, 21, 443, 53, 22, etc.
Hope this helps everyone.
By disabling these services; Windows Remote Management can still be running on the host system.
Additional Keynote: If you are using XAMPP, or Apache Win32 installer application variants; make sure to run/install as a system service. (i.e. Apache, XAMPP Apache, FileZilla, MySQL, Mercury, etc )
Disabling the Microsoft .NET NGEN is purely optional, but recommended if you are not using IIS as a web server. Granted, there are rare cases where I have seen the process use unnecessary CPU usage when port 80 is triggered by web server applications such as Apache. This could be a case-by-case basis, although I have only seen this occur in Server 2008 Enterprise Edition, and R2.
mikeblas
[H]ard|DCer of the Month - May 2006
I'm confused. You said "you have to", then you said "is purely optional, but recommended". Can you clarify which you mean? If it's optional, how would I decide if I must or shouldn't?
shaithis
Just hit the same myself...in my case it was SQL Server Reporting Services.
So many apps can grab that port by default.
userjack
Microsoft apps and 'proper' windows apps use the http.sys kernel driver for processing incoming packages on port 80 - that is they don't grab it. Real problem is Apache, Skype and the like, that use direct access.
userjack, I was going nuts trying to figure out why my System process was using 30% of my CPU usage 24/7 until I read your post - I have Skype set to open when Windows starts up. That was it. Thank you very much.
Microsoft will tell you that the cause of the System process being taken over is most likely malware. I have never had a single instance of malware on my PC in over ten years (I don't visit gambling sites, and I don't visit porn sites, and I don't open an attachment unless I am expecting it). What is offensive is that Microsoft actually owns Skype - and has owned it for some time now.
I have put a post up on Skype's beta "gremlin" forum:
http://community.skype.com/t5/Commu...-process-NT-Kernel-amp-System-and/td-p/406747
So let's see if the Skype people actually do anything about it. I doubt it. It's probably written into the bones of the Skype programme.
Anyway, thanks again for the fix!
