Poor Mans way to Water Cool a GTX 1070?
H-street
I have a GTX 1070 (Asus Turbo) and wanted just to see if there is a cheap/easy way to water cool it?
Keep in mind I am not interested in Overclocking.. just quiet and better heat management
I currently have a MiniITX build and I have a Corsair H60 for my CPU and it works very well and wanted to see if there is similarly an easy way to water cool a 1070..
my main concern are the other components like the Ram and VRMs etc..
My budget is pretty conservative so if it does involve like a 100$ water block followed by a 100$+ cooling system I would probably just live with the noise/heat since this is much more of a want than a need
RazorWind
"Supports all current blower style cards including the EVGA models below with their matching shrouds."
I take that to mean that it should work with the reference PCB design.
Peter2k
maybe this
https://www.nzxt.com/products/kraken-g10-white
fits:
Compatibility - AIO Liquid Coolers
NZXT :
Kraken X61, Kraken X41, Kraken X31, Kraken X60, Kraken X40
Corsair :
H105, H110, H90, H75, H55 , H50 (CW-9060006-WW only)
Antec :
KUHLER H2O 920V4, KUHLER H2O 620V4, KUHLER H2O 920, KUHLER H2O 620
Thermaltake :
Water 3.0 Extreme, Water 3.0 Pro, Water 3.0 Performer, Water 2.0 Extreme, Water 2.0 Pro, Water 2.0 Performer
Zalman : LQ-320, LQ-315, LQ-310
thing costs 30$ methinks
+ an AiO
Compatibility - Graphic Cards Nvidia:
GTX 1080, Titan X, 980Ti, 980, 970, 960, Titan, 780 Ti, 780, 770, 760, 680, 670, 660Ti, 660, 580, 570, 560Ti, 560, 560SE
AMD: R9 390X*, 390*, 380X*, 380*, 290X*, 290*, 285*, 280X*, 280*, 270X, 270, R7 370, HD7970*, 7950*, 7870, 7850, 6970, 6950, 6870, 6850, 6790, 6770, 5870, 5850, 5830
but all reference PCB's
the EVGA one might be a good solution too
Chapeau
Kraken works using the G10 bracket!
Actually it's pretty complete really: The AIO takes care of the GPU die and the fan does the VRM.
I had mine running at something like 800rpm on the radiator and had temps around 70 with a mega overclock. Stock speeds it is perfect...
D
Deleted member 278999
Guest
Kraken G10 with a Corsair H90 and RAM Heatsinks
Tsumi
An AIO with adhesive heatsinks is the best way to achieve what you are looking for.
Nebulous
70 with an AIO? Wow that's awful considering my 1070 clocked @ 2100/4550 will max out temps @ 58c and fans @ 40% which is pretty much dead silent. I wouldn't waste money on an AIO to cool a 1070.
If you want to go AIO, you're better off getting the swiftech MCR140-X drive and pick up a universal WB.
yeah I know this isn't a cheap way, but it's a helluva lot better than using a wimp AIO like an Asetek clone.
Chapeau
Hahahaha... I should give you some context. I used mine in an Ncase M1.
It's a tiny 12L volume so you would fit 7.5 of these inside of your case!
It's basically a solid brick once built up so 70 on a benchmark with an OC and minimal fan speed is pretty great!
Of course at a slightly higher but still quiet 1200 or so, you could drop another 5 degrees.
Nebulous
Ahh, gotcha. I tried an AIO on a 290 and it was overwhelmed with the heatload the 290 put out. The fans whaling away full bore and it couldn't tame it, lol! Yeah so 70 in an Ncase M1 isn't too shabby.Especially if the fans are at 800rpms and silent.
