No, that's a common misconception. ASRock was started by ASUS, but spun off in 2002 as Pegatron which is the parent company of ASRock. They are in no way related today.ASRock belong to ASUS, in theory the cost effective range of products.
I ve never use UEFI before, but I did read something attractive to me, that Gigabyte software loves the look and feeling of Win7.
Since P4C800-E Deluxe, I was blindly trust ASUS, it might worth now a new wind of change.
Yesterday I was looking products of both brands, product design of 2015, they were mirror image.No, that's a common misconception. ASRock was started by ASUS, but spun off in 2002 as Pegatron which is the parent company of ASRock. They are in no way related today.
Sorry, but no. ASUS and Pegatron began separation in 2009. It maintained 25% stake in Pegatron which it reduced to under 20% in 2013. This means that ASUS has zero control over ASRock and Pegatron. More data supporting this can be found here and here. Pegatron was the QDM for ASUS and ASUS' goal was to cut ties with Pegatron. So while they were once the same company, they've not been for about a decade now. What you see as similarities around 2015 is simply a result of that shared lineage. UEFI implementations, including the interface we've all come to know from ASUS occurred back when the companies were still related somewhat, with Pegatron being the actual manufacturer of ASUS' products.Yesterday I was looking products of both brands, product design of 2015, they were mirror image.
If ASUS was considering ASRock as foreign body, they would had take it head at the courthouse.
Interesting that the Asus and ASRock GUIs look similar, and the Gigabyte and MSI GUIs look similar.
To my eyes, the Gigabyte seems a little easier to read, with the text layout being a bit more spaced out and clearer.
Which do you prefer aesthetically?
I explained this earlier. They share a lineage, but the two companies have diverged since.Maybe some of those vendors outsource BIOS development to a third-party company?
I'd agree somewhat. Option labels on AMD boards are rather unusual on ASUS boards and I don't care for it.Maybe this is because i primarily build AMD rigs, but i HATE asus. Such overpriced garbage. The settings in bios have horrible labels, or like the 'above 4g decode' on first gen ryzen, just dont work at all.
One reason why I have always used ASUS motherboards for like 20+ years now, despite their lousy RMA and repair service.I own 2-3 X470/X570 boards from Gigabyte/ASUS/MSI/ASRock. Gigabyte and ASUS hands-down are the best; ASRock and MSI I always walk away thinking I would never use these for my main rig, did they just google translate everything and shipped it?
Not really. The fact is, most of the time you won't have to adjust all that many of the values to achieve the most of out your CPU. It's not until you go for a bleeding edge overclock on custom water or take it up to LN2 that you can really benefit from some settings. I do a lot of overclocking on custom water and even then, the vast majority of systems do not benefit from manipulating most settings.Are there any specific BIOS/UEFI guides (newer, not written in 2007) out there that actually explain what all the various BIOS options and settings actually do? Sure, "boot order," "peripheral on/off" toggles and fan alarms are somewhat obvious but when I see, "second-stage, PCI-E pre-charge, flash trigger x_64 legacy support" or some other crazy non-nonsensical setting I'm left scratching my head.
Also looking for: usually/ALWAYS change/set these options and for the love of god, NEVER touch these settings advice.
