So do you think it could be the cradle itself that is limiting my transfer speeds or is it more likely to be the sandisk sd card? In theory, the card should be able to sustain atleast 1.5 mb/sec, but I'm only getting around 500K/s.Originally posted by Y2K SE
I also ActiveSync my Toshiba PDA wirelessly. I also use this software for transferring files to the PDA over my wireless network.
It's definately faster than using the cradle.
the usb1 port can push 11mbits, or 1.38 mbytes/sec and with my transfers I don't think I get quite that speed...I get more like 500-800kbytes/sec, and my SD card isn't really limiting me because I believe the sd card will do 1.5 mbytes/sec.Originally posted by Y2K SE
I think that the ability of the PDA to read/write data, both to its onboard RAM and CF/SM/SC/etc media, is enough to saturate the available bandwidth of a USB 1 device. I've never seen published numbers for the actual read/write throughputs, though.
I will say that my Toshiba E750 will sync on its cradle much faster than the Jornada 568 it replaced. I use the WiFi sync method because the gold connectors on my Jornada would stop making a good connection on the cradle after a month of syncing. I would have to scuff them with sandpaper to restore its proper operation. I figured WiFi would be less maintenance.
Originally posted by sevisehda
I was thinking about getting a SanDisk WiFi SD card. My only worry is that it I'll break the antenna off when its in my pocket. Can anyone vouch for the quality of a SD WiFi card?
Is the card rigid enough that I can just leave it my PPC when the PPC is in my pocket or bag.
I'm kinda worried that the top of the card will snap off if.
yeah, socket cards are great. I use the integrated wifi on my ipaq h4355 though. Great range there too.Originally posted by DooKey
I second the Socket recommendation. I tried the Sandisk with my Axim and it was a piece of crap range wise. With my Socket I can go as far out with it as I can with my laptop.
Originally posted by Leright
Also, stray away from the ambicoms wifi cards. I had one and it died after about a month of use.
Have you managed to successfully sync remotely? I haven't been able to, yet.Originally posted by [wizard]
i sync wirelessly to my laptop. if i'm not on a wireless network i can sync via adhoc w/o having cables!
