Seems to be a pretty good deal for physx card or a back-up card. http://shop4.frys.com/product/5837943
Based on the 65nm-built G92 chip
512MB/1GB 9600GSO cards are G94-based with 48SPs enabled.as far as i know, the 512mb 9600GSOs are the g92 based ones, with only 48sp.
Yes all of them are less than the 9600gt in speed but the 384 ddr3 of the 9600 gso is very close to speed of the 9600gt
so, wait... you're saying the GSO w/ 768Mb is SLOWER than a 9600GT??
Is this really equiv. to an 8800 series? I couldn't find a 768Mb GSO version on any of the VGA charts.
Source? As far as I know, the G94 is basically the same design as G92 except with fewer components.The g94 core is about 25% more efficient than the g92 core
I think it comes from something like this, but Roland00 has it slightly mixed up: http://en.expreview.com/2008/04/02/g80-vs-g92-hi-end-geforce-gfx-cards-round-up.html/10Source? As far as I know, the G94 is basically the same design as G92 except with fewer components.The g94 core is about 25% more efficient than the g92 core
Not by a long shot. It uses a completely different GPU and board design. It's actually a cut-down 8800GT/8800GTS with more RAM.The 768mb GSO is a castrated 8800gtx
