NoxTek
The Geek Redneck
- May 27, 2002
So I was building a PC for a client and Fry's happened to have the 12X Plextor SATA drives for $69.99 with a $20 rebate making them $49.99. So we decided this would be cool since he could then have all his drives be SATA and not have a big ol' ribbon cable anywhere in the mix.
So upon opening the package and checking the drive out, I notice that the back panel of the drive is sort of suspiciously held on with 2 screws. Since there were no warranty seals preventing removal of this panel, I figured it was an invite to check things out. So out the screws came and what do you know? It's not a true SATA drive at all... it's a plain old IDE drive with a SATA bridge hurriedly slapped onto the PATA connector at the rear of the drive. Meh!
And all that noise everyone made about Plextor being the first to produce SATA DVD recorders. Poppycock! Shenannigans and tom foolery!
Anyway this ended up being a good thing, since I found out during the build that the stock drive wouldn't work in anything but PIO mode on the Abit KV8 Pro's VIA powered SATA controller. It's apparently a known compatability issue that neither Plextor or VIA see fit to resolve. (and it's probably Marvel's damn fault for the crappy bridge chip anyway). I ended up pulling the little SATA bridge PCB off of the rear of the drive (removing it from the PATA connector and power connector) and it works just fine as a normal 12X Plextor PATA drive. Because that's what it is.
I've got some pictures if anyone happens to be curious.
