This is for my server. I do mostly hosting from my house with it as in: file printing sharing, Teamspeak hosting, FTP and so on. I do a lot of lan parties and I need to use this as a game server as well during those times.
MB: Asus A7V8X-X
http://www.asus.com/prog/spec.asp?m=A7V8X-X&langs=01
FSB 333 / 266 / 200MHz
RAM: both Muskin
One stick of DDR 2400 256mb
One stick of DDR 2700 2-2-2 256mb
I plan on replaceing my ram on my main box and putting the old ram in this server.
It will have a gig of 2700 2-2-2 soon.
I been doing a search in here and read a lot. I am leaning towards getting the cheapest AMD Mobile Athlon XP. BUT only reason I would get this chip is for overclocking. Overclocking on a server, well not do sure about that. Also my Ram will be 333mhz and if I do get a Mobile I will be suck with 266fsb right?
I will be using my old SLK-800 the HUGE copper heat-sink. I was able to over clock my XP 2400 to 2.4ghz from 2.0 and get my same 2700 333 ram up to 400mhz
Budget is tight. In the rang from 60-80. I dont want to spend too much or too little. I need to get some more hdd space for my server plus buy some new ram soon and thats going to cost me. I would be willing to spend more, but only if you can show me the benifits.
Thanks for reading this mess and any help you can share
MB: Asus A7V8X-X
RAM: both Muskin
