Please help, very slow internet connection(wifi)
Discussion in 'Networking & Security' started by Jnk, Mar 20, 2004.
  1. Jnk
    Jnk [H]Lite
    71
    Mar 19, 2004
    I just bought a laptop yesterday along with a router. The installation of the router was painless and my amd k6-2 desktop was running like usual as if nothing had changed. It was pretty much the same for the laptop but when it comes to opening a web site it doesnt work or it is ridiculously slow to the point where it wont finish loading the page.
    What is happening, I am anxious to get this resolved. The communication seems fine between the router and the wireless card. It shows 11mbps and 5.5mbps most of the time but internet is slow or non existant. Please help, thanks
    Desktop: Win98 linksys NIC
    Laptop: Emachines m5312 Windows XP 802.11g
    Router: D-link DI-514 802.11b
    Comcast cable w/ motorola sb4100 modem
  2. Jnk
    Jnk [H]Lite
    71
    Mar 19, 2004
    Update, I went to dslreports.com and did a speed test. It showed download speeds of 42kbps, and uploads of 221kbps. What is going on? Its usually the other way around (download>upload). Please help, thanks
  3. Jnk
    Jnk [H]Lite
    71
    Mar 19, 2004
  4. Jnk
    Jnk [H]Lite
    71
    Mar 19, 2004
    TTT again, please help me im dying here
  5. draconius
    draconius 2[H]4U
    2,081
    Apr 8, 2002
    hrm....drivers for laptop card current? can you download netstumbler and run it on the lappy see if the signal you are getting from the WAP is constant?
  6. nurv
    nurv 2[H]4U
    2,646
    Jul 18, 2001
    If your router is anything like the 514 I bought for my girlfriend your gunna have 15 bajillion problemes.
  7. Jnk
    Jnk [H]Lite
    71
    Mar 19, 2004
    Thanks for your replies guys. I got the problem fixed by doing a system restore, IE got messed up somehow. I did another dslreports test and now it looks much better.
    Download - 2499 kbps
    Upload - 211 kbps
    Transfer rate - 305 KB/sec
