Existing Hardware:
GPU: GeForce GTX 980
PSU: EVGA 500W W1 100-W1-0500-KR 80+
SSD: Samsung 870 EVO SATA SSD 500GB
Case: Corsair 4000D Airflow Tempered Glass Mid-Tower ATX
Monitor: Acer Nitro XV272U Vbmiiprx 27" Zero-Frame WQHD 2560 x 1440 Gaming Monitor | AMD FreeSync Premium | Agile-Splendor IPS | Overclock to 170Hz | Up to 0.5ms | 95% DCI-P3 | 1 x Display Port & 2 x HDMI 2.0
Items I need to purchase that need to work with my existing hardware above:
CPU
Motherboard
RAM
Additional Info:
1) Computer use: Gaming
2) Budget: I prefer to stay under $300, but I will go up to $400 if there's a significant performance increase that's worth the extra money.
3) Location: USA
4) I won't be OCing
5) Max monitor resolution: 1x monitor at 2560 x 1440
6) Plan on buying parts ASAP
7) Special features required for mobo: a.) onboard gigabit NIC; b.) an extra PCI-E x1 or better slot in case the onboard NIC is no good and I need to add my own (this slot needs to be at least two slots away from the GPU slot so the GPU doesn't block it); c.) I would prefer the mobo doesn't have bluetooth or wifi, but as long as I can disable those in the BIOS to where they don't emit electromagnetic radiation, then I don't mind.
8) OS: Windows 10 N LTSC
Any help on this is much appreciate. Thank you in advance.
CPU
Motherboard
RAM
Additional Info:
3) Location: USA
4) I won't be OCing
