piratepress
- Feb 15, 2002
I'm looking for some advice. I just got a 260 GTX but want to make sure it will work on my Coolermaster 550w power supply. I'm presently using an 8800 GTS which requires 400w and 26 amps on the +12V rail and my Coolermaster 550 has 16 amps on each of the +12V rails. I'm concerned because the 260 GTX requires a minimum 500w and 36 amps on the +12V rail. Seeing as how I have 32 amps on both +12V rails, I want to make sure it is enough. Will it give me enough overhead or should I splurge and buy a 750w unit? Thanks!
